Home > Technical > Funny code
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
Funny code
Every time I start up my 2009 TDV8, I have noticed it gives a small 4-digit code in the centre LED in the dashboard. It said for instance "2900" this morning, which I am sure is different from the other day when it said "2700". It is only until I turn the key all the way and the engine starts, then it is replaced with whatever I have selected, the outside temp, the L/100KM, etc.
Is this something, or just me being paranoid?
KB RRS TDV8, black with ivory.
Post #235418 Wed Sep 02 2009 9:35pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Could be the next service indicator Question L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #235423 Wed Sep 02 2009 10:34pm
Killerbob
ahhh, I made a mistake:
It isn't in the centre LED screen, it is in the Odometer LED screen! Hence, when I turn the electrics on, it said "2900" this morning, and when I started the engine, it turned into the "13650" km the car har driven.
Perhaps this is a service indicator, can anyone confirm?
Post #235431 Thu Sep 03 2009 6:53am
As others have said, sounds like you have 2900 miles to go until the next service.
Post #235433 Thu Sep 03 2009 6:55am
Killerbob
I assume that would be in KMs, as that is what I have set in the settings?
Post #235434 Thu Sep 03 2009 6:58am
Alias
Switzerland 2006 Range Rover Sport TDV6 HSE Java Black
But if it is a message for the service you will see it all the time. How long do you have your TDV8?
Is the number always the same?
Post #235436 Thu Sep 03 2009 7:05am
KB
Sorry KB, yes kms if that's what you're set to Very Happy
Post #235437 Thu Sep 03 2009 7:06am
MAW
See if the number changes, there is a code you can pull IIRC by holding the odometer reset button before turning the ign key, cannot recall format but seem to think it looked like a registered date or similar....
Post #235451 Thu Sep 03 2009 8:03am
Bobby
Service Interval Indicator (SII)
The service interval indicator is displayed in the information display. This provides information to the driver warning of an impending service requirement.
The service interval is displayed for 3 seconds when the ignition is switched on providing the service interval threshold has been reached. The service interval is reset by the dealer using an approved Land Rover diagnostic system or a manual reset procedure and, once set, counts down the mileage and time in days to the next service.
The service interval varies depending on market and vehicle engine fitment. In some Eastern European countries, South American countries, Middle East and African countries and some Asia Pacific countries the SII is disabled.
Two levels of service warning are provided; remaining distance and periodic inspection.
Remaining Distance
The remaining distance is calculated by the instrument cluster by using the current odometer value and the last service reset odometer value. The instrument cluster uses these two values to calculate the distance remaining to the next service. The remaining distance value is used to display the oil service requirement.
The mileage is displayed to the nearest 50 Km or 25 miles depending on the market configuration of the vehicle. If the service interval passes zero without being reset, the instrument pack will continue counting down and the remaining distance display will show a negative (-) value.
The trigger point for displaying the remaining distance is 600 miles (1000 km) or 30 days or less depending on the market configuration of the vehicle and is contained within the Car Configuration File (CCF).
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #235478 Thu Sep 03 2009 10:40am
MAW
Tried this on my MY09 this am and it is different now the old RRS acted as above but now it pulls up a different menu Rolling Eyes
Post #235481 Thu Sep 03 2009 10:48am
