Home > Technical > drivers seat.. having alot of bad luck
ukheman
France
well after having problems with Black Smoke .. my seat no longer adjusts....
the electric controls have stopped working forward back and up and down.. the passenger works fine
i wish i could get my hands on a workshop manual.....
anyway when i press mem 1 2 or 3 is it displayed in the dash .. but no movement...
where are the fuse located ive seen the ones under the bonet..
thanks
Post #234330 Sun Aug 23 2009 1:38pm
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
in the fuse box Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
Post #234331 Sun Aug 23 2009 1:41pm
ukheman
France
thanks .. but where is the fuse box located inside the car..
Post #234333 Sun Aug 23 2009 1:52pm
V8 andy
to be honest dont really know but it will probably under either driver or pasenger footwell.
andy
Post #234334 Sun Aug 23 2009 1:58pm
Tim in Scotland
Gently remove the seat base trim or get in the rear footwell and check the connections are still OK, There may be satnav DvD and other stuff under the seat so you may end up taking the trim off anyway. You may find that the cable has got trapped and the connections pulled out or the wires have got cut.
BTW Mem 1,2 & 3 will only work the seat if there are positions programmed into the memories. If the battery has been disconnected then the memory setting may have been lost, also have you tried BOTH key fobs? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #234336 Sun Aug 23 2009 3:59pm
ukheman
France
the battery has been dead.. i thought the DVD drive was under the passenger footwell..
i will check again the base of the drivers seat..
from what i saw last time all the block connectors looked well in place... so just wanted to double check with the fuse..
but dont know where they are located
Post #234337 Sun Aug 23 2009 4:07pm
MAW
In the RHD variant, the fuse box is behind the glove box and NAV DVD player under the the LH seat.... lower the lower glove box and squeeze the two hinge clips for the box to lower further providing access to the fuse 'box'...
I think it is in the owners manual if you have that ?
Post #234339 Sun Aug 23 2009 4:50pm
ukheman
France
nop i have no manual .. any hinters why the seat controls have died
Post #234340 Sun Aug 23 2009 5:23pm
MAW
fuse box as per the above Rolling Eyes Confused Wink Smile
Post #234352 Sun Aug 23 2009 8:56pm
ukheman
France
sorted this out fuse 30amp had blown because the wires under the seat had been caught along the tracks.
managed to untwist then then just insulated with some tape and secured back down. all is good in that department
Post #234941 Thu Aug 27 2009 11:32pm
Bobby
Why don't you go HERE to download a copy of the manual.
Will be very useful. Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #234948 Fri Aug 28 2009 3:06am
ukheman
France
wicked thanks for that !!!
Post #234992 Fri Aug 28 2009 8:44am
