Home > Technical > HEAVY BLACK SMOKE |
Welcome to the forum Ukheman, sorry it was a problem that brought you to us
Sat Aug 22 2009 7:07pm |
ukheman Member Since: 22 Aug 2009 Location: paris Posts: 15 |
thanks.. i have tried to look thru the forum before posting..
Sat Aug 22 2009 7:18pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
Have you checked the various hoses (intercooler, inlet etc) around the top & front of engine, for splits / loose clips etc? BTW, I didn't think anyone in Paris would be embarrassed by people hooting their horns, I thought everyone there held them on, all the time they were in the driving seat RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sat Aug 22 2009 7:30pm |
i will check in the morning.. seems to be alot of plastic covers .. do you know where i can get a workshop cd from ? |
Sat Aug 22 2009 8:32pm |
is it easy to detect hose pipe slits ? or do they have to be check under pressure .???
Sat Aug 22 2009 8:40pm |
Unfortunately, the only source of info I know of is the LR GTR (Global Technical Reference) on the official LR website, but there is a cost involved for access as far as I know, so unless I'm desperate, I'll not be using it. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sat Aug 22 2009 8:43pm |
There is normally traces of oil present in the hoses / ducts etc, so a split would usually be noticeable by some small oil seepage there, or by a noise when under pressure. If no problem found with these, maybe try some form of injector cleaner in a tank or three of fuel to make sure they are reasonably clean to start with. Turbo problems are usually accompanied by engine warning lights and messages, and fault codes that can be read by a dealer, faulty egr valves also produce fault codes and cause drivability problems usually at slow speeds ie. no power when trying to pull away or accelerate. As you say there is no lack of power, so you shouldn't really suspect turbo or egr's at this stage. You may be better off getting any fault codes read by a dealer as it may show something as simple as a faulty sensor somewhere, which you would have trouble diagnosing yourself. If it's any consolation, if I accelerate hard in mine at night, I can see a massive cloud of smoke behind me in the following cars headlights, not quite so noticeable in daylight though, so I guess mine isn't perfect by any means. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sat Aug 22 2009 8:57pm |
KiwiRRS Member Since: 22 Aug 2007 Location: Wellington Posts: 92 |
Just had my left EGR replaced. there was no noticeable power loss, or abnormal amounts of smoke but the engine wasn't as smooth as normal. I did however have the check engine light on and an increase in fuel consumption (about 20%). |
Sat Aug 22 2009 9:42pm |
i dont think its the EGR Valves has ive seen both Exhausts boost out smoke . Read thru the forums that its unlikely both go at once...
Sun Aug 23 2009 11:07am |
couldnt see any blockages.. cleaned out the air filter.. placed some injector cleaner in the fuel tank no difference.
Thu Aug 27 2009 11:39pm |
What brand of fuel are you using - from the oil majors or "supermarket" supplied? If you have been using discount price supermarket fuel then bite the bullet and pay the couple of cents a litre more and run a couple of tankfuls of fuel bought from a Shell/BP/Texaco/Total (ie Branded) forecourt through the engine. It sounds like you might have a fuelling problem which is an ecu or sensor problem. Your car hasn't been "chipped" has it?
Fri Aug 28 2009 5:39am |
gunna do that.. i use shell and have tried some fuel additives already... i might do a full strip down of the front end to see if any botton hoses have got any splits... each way i looks its a long messy job as my mate whoes a mechanic has hedged his bets on the turbo with leaky seals..
Fri Aug 28 2009 8:53am |
Alias Member Since: 18 Aug 2009 Location: Zürich Posts: 194 |
I have also the same problem and my RRS is also from France. But I don't have a diesel particulate filter (DPF). I think that's the problem. |
Thu Sep 03 2009 7:07am |
well.. took the airbox off and looked under there.. so alittle bit of oil residue.. so got a torch and looked further down the pipe..(big thick pipe from the intercooloer onto the top of the engine)
Sat Sep 05 2009 3:51pm |
