Home > Technical > FIBRE OPTIC HARNESS damaged need tips
no_one_has_this_name
I have a 2006 hse, there are a couple of problems I have. replaced full trim and sat nav touch screen etc
part of the fibre optic cable is damaged (some thing dripped on it and burnt through) on the HK amp under drivers seat
i was thinking i could use other parts of the fiber optic harness to "bridge" the 2 damaged parts back into service sacraficing the TMC module as i dont care about that i have replaced the center console and carpet etc BUT when trascing the optics back i can trace them all apart from "2 ends"
will just looping out the TMC work after all its just a loop cirucit is it not?
i cant trace the out (2) from TMC and the (1) in for the touch screen i presumed these 2 connected together but there mst be some other module inbetween these 2 connections (poss under center console) i can take the trim etc back out but means i will be stripped out until i find: a new harness and or repair the present one, due to the fact i cant just extend or repair the cables i want to find a solution before i go in all guns blazzzzzzziiiiinng
any help with this missing or over sight on my behalf would be helpful
to confirm i have 4 ends for this loom
the touch screen
the radio
the harmon kardon amp
the tmc unit
seems simple but bet its not "ha ha HA HA" laughing all the way to the bank!
Post #234296 Sat Aug 22 2009 9:01pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
i think the CAN net can't support 'patching' like this, willing to be proven wrong
Post #234346 Sun Aug 23 2009 7:15pm
terrieremery
England 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
have you fitted sat nav to a rr which didnt have it fitted as standard
Post #234354 Sun Aug 23 2009 10:04pm
not its an hse it has options coming out of its exhaust pipes ha ha ha on a serious note i should just buy a new harness but dont know the cost am guessing around £300 what will be fine but i best prepare for the worst I think. the car came with the sat nav etc as standard
i know the system should not be patched so to speak but I cant see it having to much trouble being recoded or configured as it has to be the same setup minus TMC for a car without the TMC
will keep all updated Wink "ha ha HA HA" laughing all the way to the bank!
Post #234379 Mon Aug 24 2009 8:34am
I bypassed the TMC and it works just looped it out for now, plug and paly no reset or programing by dealers needed
Laughing "ha ha HA HA" laughing all the way to the bank!
Post #234746 Wed Aug 26 2009 8:30pm
