![]() | Home > Technical > TMC Antenna location ? |
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 ![]() ![]() |
Hi ..any body know the location of the TMC antenna (not the TMC box itself ) ..im suspecting up in the spoiler somewere ..but if any one can confirm ..pics would be great
Isn't it in the back right window??
Yep. I wasn't of the opinion there was a separate TMC antenna - the TMC data is broadcast in the RDS signal on Classic FM in the UK. Wouldn't be the first time I was wrong though |
I think i ment to say TMC antenna Amplifyer |
Not sure there is such a thing |
Trying to locate the equivelent of number 10 on above link / diagarm in a RRsport Bluetooth Exchange www.bluetoothexchange.co.uk |
I'd imagine it's going to be in a very similar location - given the diversity antenna is in the same place, and they all appear to connect into that from a short distance. I can't find the equivalent diagram for the RRS. If Bobby is watching he may have something on the topic |
It would make sence that it should be nearby ..however the amp is only connected to the TMC module via a coax cable which is not connected to the cars antenna ...so it could be any were |
