Home > Technical > Forcing front nav screen to remain in PAL |
Welcome along mate, what is it you're trying to achieve by forcing the PAL output? If we know that, some of us might be able to form a better answer for you
Thu Aug 13 2009 7:49am |
fnumber1user Member Since: 12 Aug 2009 Location: Essex Posts: 4 |
Hi Schmoogle, cheers for the welcome.
Thu Aug 13 2009 9:38am |
149 views and only 1 response thanks for looking guys, I'll post if I find out the answer |
Mon Aug 17 2009 3:54pm |
Sorry - obviously what you're trying to do is a little bit specialist
Tue Aug 18 2009 7:14am |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 |
It might be worth joining one of the sister sites, disco3and posting the question in the technical section for the attention of Wiggs & BBS, both of whom have good experience in the LR electronic systems common to both cars. Questions about 22" wheels, body kits and boobies are best left here. |
Wed Aug 19 2009 12:32pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Have you looked at setting Rosen unit to default to PAL output.
Wed Aug 19 2009 8:22pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
On cars fitted with RSES there is a way to permanently toggle between PAL and NTSC via the touchscreen, no need to enter diagnostics. You can select the color system through a submenu of the DVD menu. Unfortunately I don't know what the interface looks like on cars fitted with a TV tuner, since we don't get that option in North America. |
Fri Aug 21 2009 4:24pm |
