Home > Maintenance & Modifications > How can I open the key?
Alias8832
2007 Range Rover Sport TDV6 HSE Java Black
Is it possible to open the key?
Post #233735 Mon Aug 17 2009 12:25pm
Wink
Why would you need to open the key? Confused
Post #233737 Mon Aug 17 2009 12:28pm
Tim in Scotland
Not as far as I know - why? It doesn't need a new battery as it never goes dead...................... you put it in the ignition and it recharges through the keyhole. You should be using both keys so they both stay fully charged. The key fob is sealed to keep it waterproof for offroading. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #233739 Mon Aug 17 2009 12:30pm
Alias8832
thank you for the information.
How can I program key?
Post #233744 Mon Aug 17 2009 12:49pm
Shocked
You don't, the dealer service dept does.
So who's keys have you stolen? Confused
Post #233747 Mon Aug 17 2009 12:59pm
Alias8832
Ok I will ask LR. I hope it doesn't cost to much. I have one key which works and I bought a second one which isn't programmed.
Post #233752 Mon Aug 17 2009 1:30pm
It's not cheap to have a key programmed, not in the UK anyway.
Post #233757 Mon Aug 17 2009 2:24pm
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi
The keys are sealed for life, ive opend many for experiments Smile , it nearly kills the case opening them.
You CANT program a used key from another car to fit your car, the second key you need must be dedicated to your cars chassis number.
The keys are pre programed from landrover with the chassis number and some other spacifics that are relevent to your car, the key is a "Crypto" encritped key so the data inside is coded for security.
You are best buying a spare from landrover relevent to your car and have them program it, i think all in about 100GBP
Pete
Post #233888 Tue Aug 18 2009 10:31pm
DrLex
Iceland
One of my D3 keys stopped working, so I cracked it open (literally) and replaced the battery with a soldering iron. Whilst the opening knackered the blade spring and looks distinctly war-torn, it does now work. Keys (and car) are 4 & 1/2 years old.
Post #243850 Fri Nov 27 2009 1:23pm
