Home > Technical > engine oil flushing |
The oil in all the diesels I have owned has been black after I have got them the 20 miles home after a service. I suspect that these days the service lads (I hesitate to call them technicians as most don't seem to know how to operate anything other than a playstation) use a suction device so when it looses suction the oil must all be out............ so then they put in the measured amount and invariably overfill the engine as they didn't get all the old oil out. Hence black oil immediately after a service. With my 90 this doesn't happen as I take it to an indy and they usually have 2-3 days with it so can leave it on a ramp over night for all the old oil to drain out - with that car I also always get it back with the oil 3/4 of the way up the dipstick and it is also relatively clean.
Sun Aug 16 2009 5:54pm |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Do you mostly do short drives, e.g city driving? The EGRs put back a lot of into the engine, so oil does go black but it shouldn't so soon after a service, unless they didn't change the oil, or did what Tim says above. |
Sun Aug 16 2009 7:36pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
Comparing it with a TD5 is not the best thing to do, as this has an extra (centrifugal) oil cleaning device,which keeps the oil remarkably clean (for a diesel). RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Sun Aug 16 2009 8:49pm |
Frozen of Wiltshire Member Since: 08 Jan 2009 Location: Wiltshire Posts: 66 |
thanks for the info guys - much appreciated. Didn't know about the TD5 oil cleaner - which makes sense now you mention it. And I do mostly country B-roads and medium journeys with a few longer. Not much motorway driving and is usually pretty continuous without the city stop/start.
Mon Aug 17 2009 7:58am |
I suspect they will want to charge you a lot of labour or keep the car for 2 days to ensure all the oil is drained via the sump-plug, if there is one or it isn't hidden by some vast under engine tray that aids aerodynamics and takes 6 men 3 hours to remove! I remember trying to do my own oil change on the TD4 Freelander1 I had and gave up because of the plastic large " sumpguard" that needed a ramp, 6 hands and special tool to remove. Some owners had a special guard made out of alloy sheet and designed in a special flap that allowed access to the sump plug and oil filter. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Aug 17 2009 8:58am |
There is good access to all relevant bits, so it's not hard to change the oil yourself. You could even use a better grade than the Ford standard that LR use. |
Mon Aug 17 2009 1:54pm |
