![]() | Home > Technical > Sport & D3 recall |
ivery819 Member Since: 16 Jan 2007 Location: -- Posts: 1241 ![]() |
Recall notice for RRSport and D3 diesels regarding brake problems
Is this Oz only do you know? VOSA don't seem to know about it in the UK. |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
See also http://www.disco3.co.uk/forum/topic37874.html Like this site? Buy some RRSPORT goodies to show your support! |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
That was the exact problem i had prior to the Jindabyne trip Ivery, i actually swapped a few emails with James at CHPR to see if he had heard of it, at the time it was not a common problem, but LR Australia were starting to pull it up. Vehicle went in for new pads and rotors prior to the off road meet and came out with new vacuum pump, booster, seals etc just in time
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Thanks Ivery! I've just emailed the dealer, if appropriate they may as well do my car when it's in on Friday! |
mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195 ![]() ![]() ![]() |
This makes me hopping mad. Hadn't seen this post before. This is EXACTLY what happened to me in my MY09 RRS TDV6 HSE at the tail end of last year. Except it wasn't progressive. "Sudden" more like. Nearly killed me.
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 ![]() ![]() ![]() |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Hmmm
See the thread that I started about this. http://www.rrsport.co.uk/forum/topic13123.html?highlight= I've been mad for flipping years, absolutely years, over the edge for yonks. |
Thanks Mercury, you have described my fault exactly
Called the stealer this morning and its booked in next week. He couldn't believe that I knew about the recall when he didn't think it was "out there" yet and asked me how I knew.....I haven't let on yet... |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
What I do not understand is that the recall is for all the world except Switzerland '08 RRS TDV8
They have to remain neutral in EVERYTHING! |
Spoke to my local dealer that spotted the problem back in January and basically changed the vacuum booster, seals etc then, they will check it out on Monday and make the necessary mods when its in for its quarterly "lets find the radio problem" .. Another Pommie Bar Steward down under
