Home > Technical > supercharge strange smell?? |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
If the engine is running, then the supercharger's working - it doesn't 'kick-in' like a turbo. Sounds like you have a leaky exhaust? |
Sat Jun 13 2009 3:14pm |
Are you sure it's an exhausty smell? Couldn't be the musty aircon smell that you sometimes get?
Mon Jun 15 2009 8:47am |
rockportpurple Member Since: 30 Apr 2009 Location: scarborough Posts: 26 |
i though it was an exhaust fault at first,but its like the smell is only there when i put my foot down and the supercharger spools up,it i just run round without giving it any boot it isnt there, i have just had it serviced too and they changed my aircon,maybe it could be this?i just dont know,i will post up some pics of my car soon though thankyou for your replies i will look at both issues mentioned regards
Wed Jun 17 2009 12:08am |
mahesh Member Since: 17 Jun 2009 Location: Panama Posts: 1 |
Wed Jun 17 2009 4:18am |
Clive, what did they change in the aircon? Maybe a loose connection in one of the pipes somewhere letting in exhaust gas? |
Wed Jun 17 2009 1:53pm |
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 |
You say " when your supercharger kicks in".....it is working all the time so perhaps the smell is actually unburnt fuel as all the SC's overfuel by a massive amount to cope with the crap fuel quality in the US.... If |
Wed Jun 17 2009 2:18pm |
crikey the smell that can knock us out doesnt sound good,i will try and expand a little bit more,,when i have my dial set at anything for climate,even switched off when i trundle around under a set speed it is okay,when i give it some wellie,and the supercharger spools up i get a carbon/exhaust smell through the upper vents(unless they are switched off) i recently had it serviced 15k service and it say on the invoice forte advanced gas treatment,they changed my cabin filter and ace filter if this helps,but i had the car out today and it did the same,my tail pipes are very black round the edges very sooty looking,and to top it all off,i have my dreaded knock back after new ball joints/anti-roll bar bushes,to be told its now my bottom arm bushes that need replacing,and now my front tyres are showing thread from wear,so need to getsome tyres asap,but LR say it the wear is from my lower bushes, will it ever end,after new compressor for my supension twice,my aircon,and suspension woes i thought this car was top off the tree,im considering getting a cayenne,but might see waht the new RR in oct looks like,i have done 16k since oct in this car and i love ot to bits but there is only so much i can take now thankyou for your replies i will keep you updated on the out come
Wed Jun 17 2009 10:22pm |
I don't think it's got anything to do with the supercharger, but I could be wrong. Maybe time to change your dealer or get someone like 'ten for cash' ( an independent, travelling mechanic over on www.disco3.co.uk) to have a look for you.
Wed Jun 17 2009 11:13pm |
hi all well i've had it back to the dealers and they say there isnt any smell,but when i picked it up drove round the corner hey presto,so i went back and took the service manager out with everything switched off no air-con,nothing on at all,and he said they dont know what else it is,and they want my car for 3days to diagnose the problem,soi will be in touch at a later date with a reply
Thu Jun 18 2009 1:40pm |
Hi all well just an update as to the smell,the dealership have had the car twice now,and they think its overfueling and its got to have a remap,but i have to pay for it but the last people to reflash it was the dealership due too a o2 sensor that went down,not happy at all after three weeks of fiddling so re-bboked in next week to hopefully end this
Fri Jul 24 2009 6:03pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
I think that is BS - IIRC the flaps are fixed i guess for heat dispersion / venting.... I recall seeing them when fitting towing electrics and there's no 'computer control' of them on mine! |
Fri Jul 24 2009 6:31pm |
hi all well the dreaded smell is no-more the stealers found my rear tailgate seal was shut properly and they had an enginee lay in the rear off the car and drive around new seal re-seated top tailgate and hey presto!!
Fri Aug 07 2009 5:43pm |
Ah, good to know they've found the problem and resolved it
Mon Aug 10 2009 9:05am |
RANGE_LOVER Member Since: 01 Jun 2009 Location: London Posts: 306 |
Mon Aug 10 2009 9:52am |
