Home > Technical > Which transmission does the TDV6 have?
McBunny
Hi all,
does anybody know which transmission the TDV6 has? I know of course it is a 6-speed-automatic but does it have a certain name (or number), from which manufacturer is it, which cars have the same, etc.?
Thu Aug 06 2009 3:28pm
McBunny
Wow, that was quick, thanks!
Do you know other cars that have the same transmission (Jaguars, Fords, BMWs?)? RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration
Thu Aug 06 2009 3:29pm
Martin Site Administrator & Owner
I don't understand why RRS and D3 are listed in the "two-wheel-drive" list but I think the transmission guy does understand that list and knows what to do now, thanks! RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration
Thu Aug 06 2009 3:46pm
It's because the transfer box fitted to the D3 and RRS handles the 4WD function, not the gearbox itself Like this site? Buy some RRSPORT goodies to show your support!
Thu Aug 06 2009 3:53pm
McBunny
I see, thanks for the explanation. RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration
Thu Aug 06 2009 3:57pm
Bobby
One of the first explanations from LR regarding the ZF 6HP26 transmission introduced with the RRS was:
The ZF 6HP26 transmission is an electronically controlled, six speed unit. The transmission is manufactured by ZF Transmissions GmbH in Saarbr�cken, Germany. This transmission represents the latest in automatic transmission technology and incorporates new features to enhance the transmission functionality:
The hydraulic and electronic control elements of the transmission are now incorporated in a single unit located inside the transmission and is known as 'Mechatronic'
Another new strategy is Adaptive Shift Strategy (ASIS). ASIS represents the continuous adaptation of shift changes to suit the driving style of the driver which can vary from sporting to economical.
The transmission is controlled by a Transmission Control Module (TCM) which contains software to provide operation as a semi-automatic 'CommandShift�' transmission. TheTCM allows the transmission to be operated as a conventional automatic unit by selecting P, R, N, D on the selector lever. Movement of the selector lever across the gate to the'M/S' position puts the transmission into electronic 'Sport' mode. Further movement of the lever in a lateral direction to the + or � position puts the transmission into electronic manual 'CommandShift�' mode.
The 6HP26 transmission has the following features:
Designed to be maintenance free
Transmission fluid is 'fill for life'
The torque converter features a controlled slip feature with electronically regulated control of lock-up, creating a smooth transition to the fully locked condition
Shift programs controlled by the TCM
Connected to the ECM via the High Speed CAN for communications
Default mode if major faults occur
Diagnostics available from the TCM via the CAN
Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Thu Aug 06 2009 11:18pm
McBunny
Thanks a lot for the information!
It is very interesting, thank you!
However I needed the info for Tim Eckart who is some kind of transmission-god in Germany so I am sure he was already satisfied by getting the name of the transmission. RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
