Home > Maintenance & Modifications > Battery went flat now wont start |
shuzzy Member Since: 02 Aug 2009 Location: West Yorkshire Posts: 143 |
Hello.
Wed Aug 05 2009 12:08am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
From where did you acquire it? Can you not return it for attention there ? ( I know physically you cannot)... but have them attend and address.... |
Wed Aug 05 2009 6:53am |
dare u Member Since: 05 Aug 2009 Location: Malaysia Posts: 10 |
Once the fuel is pumped in the engine, then you will have to take the engine apart to clean it off...going to cost... |
Wed Aug 05 2009 8:12am |
Have you had somebody check that the preheater plugs (aka Glow Plugs) and fuel pump are all working - there is a fuel pump reset that you can check hasn't accidentally tripped but I couldn't tell you where it is. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Aug 05 2009 9:37am |
Thanks for the advice guys. In response to some of the questions, I bought the car from a garage approx 40 miles away, not really sure where I stand in regards to come back. However I think panic over it has been fixed. I didn't think it was ever a misfuel issue as the car wouldn't have driven so long with no issues. But the useless cashier checked the receipt number and said unleaded had been dispensed.
Wed Aug 05 2009 11:35pm |
Thu Aug 06 2009 7:35am |
Wasn't just me then
Thu Aug 06 2009 7:47am |
Sorry for the confusion, but the reason I thought it was a misfuel issue is because somebody suggested it might be a reason why it wouldn't start. Therefore as a precaution I called the garage where the fuel was dispensed from and asked them which fuel had been dispensed on my receipt number. I was informed unleaded fuel so that is why I though I had put petrol in. The more I thought about the more I thought this was not the case. This was confirmed when the electrician just reset the ECU and it fired up fine.
Thu Aug 06 2009 7:56pm |
