![]() | Home > Off Roading & Green Laning > Locking into extended offroad height |
JMC Member Since: 17 Mar 2006 Location: Aberdeen-Angus (Where the Bull**** comes from!) Posts: 11 ![]() ![]() |
Just to expand on this Tim, the foot on brake/push up for 5 seconds doesn't lock it at extended mode. It actually extends it even further into 'super extendy mode'. |
4wheeldriver Member Since: 13 May 2009 Location: Aberdeen Posts: 955 ![]() ![]() ![]() |
Bloody troublemakers these FFRR drivers..................... |
Maverick Member Since: 08 Mar 2008 Location: Aberdeenshire! Posts: 122 ![]() ![]() |
Yes John, but you still had to take off your tow bar!! |
Roland Member Since: 10 Jun 2005 Location: NB Posts: 469 ![]() ![]() |
Very interesting , Tim. I'll certainly try this out. Thanks for posting! |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
keep a block of wood cut to length that fits between the ground and the chassis rail and lower the car on to that then the car will extend, or if you are cheap like me just use the jack and it will do the same |
Did you ever get these videos up on the web?? Maverick off disco3! Drives white 1996 Defender 90 300TDi R.I.P. Smudge! 24.10.08 R.I.P Hesko! 29.4.09 |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Don't blame/thank JMC, I showed him in an eversohumble D3!!! |
RichardM Member Since: 24 Sep 2009 Location: Herts Posts: 745 ![]() ![]() |
What is the easiest way to get it into extended height? Where should I put the jack? Should I lower the car onto the jack> |
Keep the car in standard hight, put the jack under and a little weight on it, then lower the car, the car will detect that one wheel is coming up off the ground and then panic... and put the car up into extended mode.
Jimmy Salsa Member Since: 03 Mar 2009 Location: Hunter Valley Posts: 257 ![]() ![]() |
How long can you keep it 'locked' in super extended mode?
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
Ive had it in super extended mode and it does auto lower, I cant recall at what speed that was though? |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
`Like low access mode their is a speed limit restriction, in Super extended mode think it is around 8mph, when this is exceeded it will lower to normal off road height |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
I think the easiest solution for more clearance is to use shortened rods. |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
The limits for extended or emergency profile are roughly 8kph (5mph) or 45 seconds of travel. After either of those conditions are met it will lower to off-road.
