Home > Technical > Parrot kit
mj345c
England 2006 Range Rover Sport 4.4 V8 HSE Bonatti Grey
Parrot kit
Hi i am looking at fitting a Parrot mki9200 kit to my 2006 RRS HSE as it it does not have the LR bluetooth fitted as standard, has anyone had this car kit fitted as it also will connect to the Ipod and has a color display? i presume i also need a Mute harness but thought id check out on here before i went for it!
any issues suggestions are appreciated
cheers MJ Shocked dont let the Sh*t grind you down
Post #231683 Thu Jul 23 2009 10:01pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
I have the Parrot 3200 colour fitted. V.good unit.
Justcarkits.co.uk are highly recmmended for getting advice and even sent the mute harness straight to Australia!!
Post #231685 Fri Jul 24 2009 1:32am
Tim in Scotland
In my last RRS, which was an early SE without PTI, I had the CK3100 and it was brilliant. It was fitted by the local LR dealership and was wired into the audio so it auto muted it when I want to make a call or there was an incoming called to be answered. It paired without any modification with every phone I owned at the time. It's simple and works. IIRC the mute harness came with it.
Last October I ordered the Parrot RK8200 to fit into my Defender................................ I'm still waiting for it! The local Halfords had them in stock but within days they took them off the shelf. Apparently it was released to the market but was then recalled within days as there were problems with some of the rather Hi-Tech bits of it. http://www.parrot.com/uk/products/car-stereos/parrot-rk8200 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231693 Fri Jul 24 2009 8:30am
mj345c
Thanks, i am being told that because the RRS has Sat nav and the Harmon Kardon stereo, the kit is not compatable, and it only uses the front speakers, which isnt a problem with the phone but as it has Ipod connectivity it would be a shame not to use all the speakers? not sure if it just the guy trying to sell me the CK3200 instead and trying to put me off the MKi9200
any ideas anyone????
thanks dont let the Sh*t grind you down
Post #231747 Fri Jul 24 2009 1:28pm
Tim in Scotland
Is the guy selling it an audio/ phone specialist or your friendly Land Rover Dealership? I would suggest if it is the former then you contact the dealership and ask them if it is possible - my TDv6 SE had no HK,no satnav and no PTi so it was a simple job for the dealers guys to plumb in the 3100 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231757 Fri Jul 24 2009 2:51pm
mj345c
ok will ask the dealer, but when i mentioned it to them last they didnt seem too interested as it was aftermarket and not through LR
i suppose its the Ipod connection that is causing the issue straight forward phone klit isnt a problem it seems
cheers dont let the Sh*t grind you down
Post #231779 Fri Jul 24 2009 4:10pm
Have a chat with justcarkits.co.uk - very knowledgable chap. He fitted my Parrot in the poxymobile and I put 2nd onto them. As he says they were even able to help him being on the other side of the planet Thumbs Up
Post #231925 Mon Jul 27 2009 10:40am
jkp
Scotland
I have the 9200 in my van. Charges my iPhone and allows me to play my tunes via the van speakers. A good bit of kit. Thumbs Up Need detailing or cleaning products, drop me a pm for forum discount prices.
If you dont want to clean it yourself, give me a shout for a quote on your detailing requirements. From a simple valet to machine polishing to remove bramble rash and swirl marks.
Post #231928 Mon Jul 27 2009 11:19am
gianluca
Italy 2006 Range Rover Sport TDV6 HSE Java Black
Have a look at my gallery.
Don't remember the number of my Parrott, but as far as I remember it's just the one you are looking for. My gallery: http://www.rrsport.co.uk/gallery/thumbnails.php?album=994
Post #231975 Mon Jul 27 2009 9:35pm
