![]() | Home > Technical > NAV Disabled options |
Welcome to the forum Moc.
moc Member Since: 22 Jul 2009 Location: Wakefield Posts: 6 ![]() |
Thanks Tim,
tclynes Member Since: 25 Jul 2009 Location: Norfolk Posts: 32 ![]() ![]() ![]() |
when you say nearly disabled would it happen to be only when you are moving?
Good point Tclynes, LR did a mod after the secret hack code got out, I think for 2007MY so it will apply to all cars built after Sept2006. I'm sure if you look back in archives using the Search function - Nav on the Move, you will find the hack code for it. The "fix" for Moc in this case is to check what dealer upgrades were made to the car while it was still in warranty and if it was taken to a franchised dealer for servicing. Any UK dealer can retreive the service and car history from the LR database, with the VIN number 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hack is either 1471 or 1741. 2005 Zambezi TDV6 - Gone but not forgotten
ahhh !!
Yep, the hack is actually 1791 - see this post to see what we mean by that |
I must stop giving everyone my PIN! |
You changed it from 2121 then VA? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Done it, fixed it - THANKS GUYS ! |
The latest Satnav DVD will be suffice - when you insert it for the first time it will do the necessary system software upgrade and bring you up to the latest version |
OK so got a later DVD off fleebay, 2007 / 2008, loaded it fine and it upgraded the firmwear.
