Home > Technical > Brake Failure - Any Ideas!
Trucker
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
RRS 06 HSE
Yesterday I experience a scary situation whiles travelling down a country lane towards a t junction, as I approached with no one in front of me I applied the brakes several times gently as I neared and then applied them firmly as I reached the end of the road, it was at this point that I seamed to loose the full capacity of the brakes and the pedal went hard. On releasing the brakes all was fine again, however if I gently pump the brakes before applying them hard it causes the same effect. Check all fluids and they are fine, pads and discs are all within limits. Not Brembo.
Post #231935 Mon Jul 27 2009 12:32pm
MAW
LRA / Dealer immediately Shocked
Do not recall that on here before...
Post #231938 Mon Jul 27 2009 12:58pm
Me neither, but presuming you still have LRA get them out straight away - that could've been you in the back of another car or worse into a child crossing the road in front of you and you would have been powerless to stop it Shocked
Post #231942 Mon Jul 27 2009 1:54pm
Tim in Scotland
Don't forget that you still have your EPB which will halt you very quickly, with ABS, if you pull up on the switch and keep pulling up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231943 Mon Jul 27 2009 2:35pm
MAW
Shocked Is that correct Tim, at all speeds or under a certain #...?
Post #231951 Mon Jul 27 2009 3:46pm
Springer
United Kingdom 2013 Range Rover Sport SDV6 HSE Rimini Red
It works at all speeds. I was at LRE Snowdonia on Saturday and we talked about this very thing. The instructor had been in a RRS and applied the EPB under race track conditions at a speed in excess of 100 mph and the vehicle stopped better and quicker than using the footbrake. He also said you only get about 2 goes with the EPB before you need to change pads.
Post #231953 Mon Jul 27 2009 4:04pm
I was on an LRE once where they demo'd this too - he described it as the opposite of launch control Wink
Post #231955 Mon Jul 27 2009 4:08pm
CarlW
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Sounds like you’re exhausting the vacuum in the brake servo. I'm no expert but worth reading through the post on the D3 site:
http://www.disco3.co.uk/forum/topic34413.html?highlight=vacuum
Post #231964 Mon Jul 27 2009 7:21pm
Tim in Scotland
So long as it works on the one time you REALLY want it to then I'm happy to know it's there and yes it works from all speeds and since I played with it on my Tdv6 and was very pleased it worked I haven't needed it on the TDv8 yet! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #231965 Mon Jul 27 2009 7:26pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Refer to this recall topic:
http://www.rrsport.co.uk/forum/topic14969.html
Post #233620 Sun Aug 16 2009 2:34am
mercuryl
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
I used the electronic park brake, for real, in a very similar situation to this.
It does not stop the car very quickly at all. In fact, very slowly.
This is becoming a serious matter.
See this post:
http://www.rrsport.co.uk/forum/topic13123.html?highlight= I've been mad for flipping years, absolutely years, over the edge for yonks.
Post #233626 Sun Aug 16 2009 7:05am
Leo
Kenya
mercuryl wrote:
I
Hence the worldwide recall for TDv6 RRS and D3....
Post #233643 Sun Aug 16 2009 8:26pm
Texstar
So very serious in fact, , that I have heard diddly squat from LR about this Whistle , even after mentioning diminishing brakes, and after having a so called 'health check' on my vehicle . Appalling Evil or Very Mad they just do not give a damn about anyones lives at risk here, and almost as bad, they seem to not have a clue as to what to do about it, or even the VIN no's of affected vehicles.W Censored RS. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #233644 Sun Aug 16 2009 8:40pm
Some service depts will need to be made aware of this by their customers evidently, which isn't entirely surprising. The world of customer service in the UK simply doesn't work how you'd want it to.... Sad
Post #233677 Mon Aug 17 2009 7:18am
Tim in Scotland
There are a few members who have resorted to printing out entire threads from RRSport.co.uk and even TSB's that Bobby has told us about and taken the printouts along to their friendly service manager to convince them that there IS a Land Rover fix for a problem........................... FBH's come to mind as one topic. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #233685 Mon Aug 17 2009 7:32am
