Home > General > loss of power ... need to know what you guys think
johnlandy
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
hi..please help and advise if poss.. have a power failiure in my rr sport tdv8 auto , 08 , done about 25 k miles..... it happens when i accelerate quite rapid , the dash displays transmission failure and ecu mode , lowers my suspension,engine still runs but no gears or power when i pull over stop and restart the ignition its ok ... start yesterday its happened about 4 times now ... worried its gonna do it when im overtaking, is this a common fault what things do i need to make the dealer check , up the mariners
Post #231245 Sun Jul 19 2009 6:28pm
rrsjo
Just get it to your dealer asap - he will do the rest. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #231378 Mon Jul 20 2009 9:46pm
KiwiRRS
New Zealand
Fuel pump or fuel filter
Had this happen - no engine power and a maximum speed of about 4kmh; not good at rush hour crossing an intersection! Turned out to be the fuel pump required replacing. No longer have this problem - now just need to fix the moving seat after it was replaced for clunking, fix the gps display as it flashes and now in tomorrow to have the check engine light checked - apparently the MAS is on the way.....please no more.
Post #231385 Tue Jul 21 2009 2:22am
johnlandy
thanks for your reply ... got it back from the dealers they said the codes indicated a fuel problem ... something to do with injector 2 .... they reset the codes tried to make it happen again but it wont , can't make my mind up if they have just fobbed me off or sorted it ?
Post #231444 Tue Jul 21 2009 4:02pm
DMike
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
If it happens again, try replacing the fuel filter Thumbs Up
Symptoms sound very similar
Post #232458 Sun Aug 02 2009 4:37pm
