Home > General > Does anyone else get a driveline shunt at low speeds?SORTED!
Page 3 of 5 <12345>
buckblue
2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
My RRS HSE is a 4.4L naturally aspirated V8
get the same loud sound that tears my heart apart! tried to explain it later but couldnt put it in the right words!
its really annoying and makes me always hesitant taking off at low speeds after braking, i doubt our local stealers will fix it here, stuck with it i guess, disappointing indeed..
feels like an american ford bronco or something! still the RRS though
Post #206462 Sat Jan 17 2009 10:10am
smidge
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Just joined the forum, wish I had a couple of months ago!
To add to this I have a 4 day old (in my hands) TDV6 HSE and yes I have the same problem, driveline shunt, lovely knocking as we drive around the country lanes here in deepest Somerset....will be speaking to the dealer tomorrow....had the same problems with the 4.2 S/C dealer assured me about the fix on the knocking from front suspension "all cured" he said...pah!
Big Cry Steve
Someone who used to own a 4.2S/C then in a moment of weakness went diesel.......
Post #229687 Sun Jul 05 2009 11:23am
challigan
Scotland
Seat rocking......
ChrisP, I had the issue where my seat 'rocked' when braking or accelerating - mine's a RRS TDV8 HSE MY08 - took it back to the dealer within first three months (twice) with this, second time they replaced the seat and since then no more rocking or seat movement. They had replaced the whole seat mounting but said they hadn't seen this before! If in warranty I'd get it back to the dealer!
Cheers, Colin
Post #230520 Mon Jul 13 2009 10:20am
dsingeruk
2006 Range Rover Sport TDV6 HSE Java Black
I love these forums!
I have this problem too, and am desperate to find the solution - its great to know however that I am not going mad and imagining it.
The jolt is horrible, becuase it feels every time you accelerate from a short period of coasting your wrecking the gearbox with that horrid thud as it picks up drive.
Anyone come to a conclusion as to the true solution?
Post #242001 Wed Nov 04 2009 3:46pm
No as far as I know there is no solution. It was one of the reasons I sold my previous RRS. The other reason was the RRS was knackered!!!!! 2005 Zambezi TDV6 - Gone but not forgotten
Post #242004 Wed Nov 04 2009 3:56pm
dfy123
Shunt Problem
I thought it was just me i have a issue where im plodding along around 30MPH foot more
or less off the accelarator and the RR starts shuddering the issues does not go away till i start accelarating any fixes recommended
my car is a 2010 3.6 V8 diesal
Post #281198 Fri Nov 26 2010 9:15pm
marksgd
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Re: Does anyone else get a driveline shunt at low speeds?SOR
Diablo wrote:
Gents,
I drove my wife's RRS HSE over the weekend and noticed and low speed shunt in the drive line. Say for example you take your foot off the throttle at a low speed e.g. 20-30 mph, and then reapply the throttle it is not smooth. There is a noticeable shunt just as you reapply the throttle. Is this normal?
Many thanks
Diablo yes mate i do get the same shunt thought it was the antiroll bar bushes ,But it wernt Sad Ill just live with it for a while
Post #285874 Fri Jan 14 2011 7:59pm
dsingeruk
On one hand this is very reassuring - Ive had this problem for nearly 2 years now...on the other very upsetting; my dealer also said "yours is one of the better ones" and left it as "wont break anything,.. just adjust your driving style". aaaaghh!
Do we have any kind of consensus as to the solution? - reprogrammed ECU or new gearbox?
Im sure the constant take up of the slack is going to have a knock-on effect and break something else over time?
....anyone recommend the 'best' technical dealer in the UK so I can go and get their opinion?
D.
Post #293638 Fri Mar 25 2011 12:14pm
Tboner
Re: Shunt Problem
that is fixed with the software update at the dealers , it is when the car cannot make its mind up which gear to select 2014 5.0SC AB
Gone 5.0 SC
Post #293644 Fri Mar 25 2011 12:40pm
marksgd
Booked motor in this wendsday for a gearbox/transmission reset & update hopefully it will sort it. Local dealership said it would possibly fix the shunt for a while but it would more than likley returne as most of the range rovers have this problem Bye the way have not booked it in with dealership ive booked in at AllTrack4x4 they are checking Transmission oil levels & update/ reset £45.00 Hopefully it will feel a bit better...
Post #293992 Mon Mar 28 2011 8:49pm
marksgd
Sorry Posted this in the wrong thread i think Embarassed
Any way its been updated the transmission that is. And it seems to have done the trick no more shunts or very little its not 100% but its 90% improvement Thumbs Up
Post #294695 Fri Apr 01 2011 8:01pm
nic
i have a 56 plate with 37k on and im having all the same issues , with a "low coolant level" warning added into the mix ...
not sure how such an expensive car can have so many naff issues .. bloody annoying
Post #300811 Thu May 26 2011 1:12pm
marksgd
nic
the low coolant warning, is the senser in the bottle live with it or get a new water bottle they are only about £15.00.
Thats if the water does not keep dropping mind you. Bye the way my driveline shunts are back Sad
Post #300851 Thu May 26 2011 5:46pm
shakeapaw
yup, had this problem a week after i had the car, happened twice in the same hour, but has not happened since Shocked
Post #325416 Sat Dec 17 2011 12:04pm
shakeapaw
and its not happened since, however i now have the coolent low level fault Rolling Eyes 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #327246 Sun Jan 08 2012 4:36am
Page 3 of 5 <12345>
