Home > General > Power tailgate (soft close ) stopped working
mercuryl
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
The powered tailgate closing thing on my two month old MY09 RRS has stopped working Big Cry
You know when you close the tailgate, the last little bit of closing happens electrically? Well that's the bit that has stopped working. The tailgate is actually mostly shut and kind of latched by that point. You can only open it again when you use the key. So I CAN still drive the car. However, the interior light comes on and the instrument panel shows a 'tailgate open warning. .... and I am a bit worried that it will fly open when I drive.
Has anyone had this happen before? Is there a simple reset? .... or is it a trip to the dealer for a warranty repair? I've been mad for flipping years, absolutely years, over the edge for yonks.
Post #204256 Thu Jan 08 2009 2:02pm
Wozz
Someone posted recently that if you press lock and unlock together on your keyfob it might fix talgate problems. Worth a go as it solved it for me on my 09 RRS when that locked up half closed the other night. WINNER - 2009 Best Newcomer Award
'09 TDV6 XS Stornaway Grey
'06 BMW 730 D SE (Gone)
'08 A4 TDi SLine Avant (Gone)
Large pack of Flake Cakes (Gone)
6 pack of Guiness (Gone)
Post #204257 Thu Jan 08 2009 2:06pm
Try what Wozz said hold lock and unlock on the key for 3 seconds RRS TDV6 Gone but still around
Post #204258 Thu Jan 08 2009 2:34pm
Yep, that was all news to us but definitely worth trying. You may find that because the hatch is not in the open OR closed state, the auto close doesn't kick in. If you can open the tailgate again using the trick above, then attempt it I'd expect it to auto close again. If not, might be worth a trip to the dealer.
Post #204259 Thu Jan 08 2009 2:34pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Sounds like a trip to your local Dealership to me.
It could be a simple blown fuse or if someone has been a bit heavy handed in slamming the tailgate you could have Censored up the soft close mechanism. I hope I'm wrong but it's worth getting it checked out properly. Either way it will be covered under warranty.
Good luck Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #204516 Fri Jan 09 2009 9:03am
MAW
The recent post by Bobby was hold unlock and lock on the dash for 3 secs - i don't know the keyfob does the same thing
Post #204519 Fri Jan 09 2009 9:06am
Bobby
I didn't know either! Shocked Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #204523 Fri Jan 09 2009 9:11am
MAW
Just tried - it doesn't (on mine)
Post #204525 Fri Jan 09 2009 9:13am
Wozz
It works on the keyfob on mine as well as dash. Apparently (according to the manual) this also cycles betwen secure entry (drivers door only) and open entry (all doors) on one button click on keyfob.
If it was me reading this I am sure I would be making some pathetic juvenile joke about secure and open entry but thats just the kid in me trying to get out. WINNER - 2009 Best Newcomer Award
Post #204535 Fri Jan 09 2009 9:28am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
hold the black boot release button down for 12 seconds, while the top part of the tailgate is open
this is how the dealer fixed mine
if you open and close the boot too many times in a period of time (4 in a minute?) the power close function shuts down as it suspects a problem. the above technique resets it.
Post #204728 Fri Jan 09 2009 6:12pm
Bobby
I thought pressing and holding the lock and unlock buttons on the remote for 3 seconds is to enable/disable the single-point entry feature only! Shocked
Got to admit I don't know much on the 09 models, though... . Crying or Very sad
Anyway, good for you! Thumbs Up Malaysia Boleh!
Post #204819 Sat Jan 10 2009 1:50am
mercuryl
Aha, that was interesting. It didn't work, because I discovered that the electric button to open the tailgate glass doesn't work. It used to before this problem happened. Also, I have noticed that the tailgate wiper doesn't always work - particularly when the car is not moving.
I now think it might be a fuse issue .... but I can't identify which fuse would operate the 'soft close' tailgate mechanism (the manual doesn't say) .... and is it related to the loss of power on the tailgate glass. ... or is this not a fuse problem at all? I've been mad for flipping years, absolutely years, over the edge for yonks.
Post #204951 Sat Jan 10 2009 11:44pm
MAW
But if the full door is open you'll not be able to open the top half anyway - they are interlocked. Again the wiper might be interlocked to an open boot door in the same way (as maybe the rear washer). It obv may be fuse related but the interlocking of these doors could also explain what you report.
Aside of these other variants cropping up - does the 3 sec dash reset suggested not make any difference?
Post #204959 Sun Jan 11 2009 7:55am
mihakrapez
Slovenia 2006 Range Rover Sport TDV6 HSE Java Black
Are all RRS HSE equiped with soft closing booth or is it optional (mine takes quite a force to close)
Post #229630 Fri Jul 03 2009 8:58pm
Bobby
You don't have this feature, it was introduced later. Wink Malaysia Boleh!
Post #229631 Fri Jul 03 2009 9:40pm
