![]() | Home > General > Low Power Mode |
Lower Power mode always comes on when engine is off. 2005 Zambezi TDV6 - Gone but not forgotten
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 ![]() ![]() |
Mine has been on when the engine is running, only thought when i have the Ipod connected. |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Maybe your battery needs changing? just guessing though. |
as mentioned had just been on a long run....so i don't think that is the case, seems a little odd. |
Hmm, a fault somewhere. As VA said, you're only meant to get low power mode if you sit with the radio on for some time after switching the engine off - you notice the volume decrease and another period after that, the radio will actually switch itself off. It's a battery saving measure as you rightly point out. |
if the battery is approaching the end of its life, it won't hold charge. However, this is usually accompained by other signs like random warnings e.g. transmission warning etc, so maybe not the case here. |
