![]() | Home > Maintenance & Modifications > Side steps problem |
terrieremery Member Since: 07 Dec 2008 Location: devon Posts: 35 ![]() ![]() ![]() |
ill be interested in this because ive got the same job to be done and sills are not available,i wonder if you could substitute the bolts for dome torx screws with a lower profile |
IanR Member Since: 10 Nov 2008 Location: Derbyshire Posts: 22 ![]() |
Hi there UB... In reply to your message there is NO problem, the bolts heads sit above the 'grove' . . . I fitted a second hand pair and simply cut the existing sills with a hot wire, it took some time ensuring they were cut to the right fit now all fit perfect and looks GREAT |
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 ![]() ![]() |
I have just bought and fitted some new side steps and they did not come with a replacement plastic sill. Instead they supplied a paper template so i had to use my existing sills, a little time consuming but i got there in the end.
