Home > Maintenance & Modifications > steering wheel and tv questions
Roland S
Scotland 2006 Range Rover Sport TDV6 HSE Zermatt Silver
can anybody help please
is the steering wheel ment to sit slightly anticlockwise in strait ahead position (mine does)
think i have read most of the threads about fitting tv but not much about fitting with factory rse is it any easier? i presume i could connect a tuner to the av inputs and select it for rear screens but what about the front is there an easy solution not to bothered if it works on the move in the front. thanks.
Post #225934 Mon May 18 2009 10:36pm
Steering wheel should straight ahead... if it's not, you'll need some alignment work doing.
The "factory" RSE is what is says... fitted at the factory, so it's not something that is easily retrofitted but there are plenty of aftermarket integrated TV solutions - a good search of this forum will show some decent results.
Post #225945 Tue May 19 2009 6:53am
Also search our sister site disco3.co.uk - there are fairly comprehensive electric discussions there too. 2005 Zambezi TDV6 - Gone but not forgotten
Post #225958 Tue May 19 2009 8:30am
Roland S
sorry should have made my self clearer i already have factory rse fitted but want add tv option. i was under the impression it came with tv but if it does i cant find it or am i missing something no mention of it in rse handbook. thanks again
Post #226022 Tue May 19 2009 8:31pm
Only came with the option of a tuner from MY08, so on your MY06 it's not there.
There are aftermarket tuner solutions.... again, search here and over on D3 for the options available to you Thumbs Up
Post #226073 Wed May 20 2009 8:51am
