Home > Off Topic > Boxster Forum |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Have you tried burning off the brakes? If it's been stood for six months you could just have a bit of rust on you discs. The pads will touch if there is the tiniest amount of play in the bearing (and make a scraping noise). If the noise stops when braking then thats it. Give the brakes a good bed in and see how it is after that. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Fri May 15 2009 10:26am |
JavaSport Member Since: 27 Dec 2006 Location: Up in the clouds Posts: 51 |
Thanks for the information and to be honest that's exactly what it sounds like but i just can't understand why it would only do it round the corners rather than the whole time but as you say if there's a little play in the bearings that could be my answer
Fri May 15 2009 10:39am |
The Boxster forum is at boxa.net, by the way
Fri May 15 2009 10:41am |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Good bunch of guys over there, they saved me from buying a Boxster.............I mean that in the kindest possible way, naturally L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Fri May 15 2009 11:11am |
Excellent i'll have a look over there and see if i can see any other things to look out for!! Thankfully it isn't me that's bought one just thought i may be able to steer my old man in the right direction (ok so maybe it's too late for that ) but from now on |
Fri May 15 2009 11:33am |
Fri May 15 2009 12:15pm |
