Home > Maintenance & Modifications > steering switches for telephone |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
does anyone know where I can purchase seperately the telephone steering switches?
Mon May 11 2009 7:04am |
Hmm... I suspect if you had a faulty set of switches, they'd probably just swap the steering wheel, giving you a new set in the process. You have a problem with them, crowej?
Mon May 11 2009 7:27am |
No problem with them, I actually don't have bluetooth.
Mon May 11 2009 8:17am |
Ah, OK.... if you have no PTI then I'm not sure the wiring is there in the first place but someone like Bobby or TB would probably be able to confirm
Mon May 11 2009 8:22am |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
You would have to buy a new steering wheel as the buttons can't be retro fitted. But even then I'm not sure if you would be able to use the integrated system as you still won't have the telephone ECU or required software loaded to the car. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
Mon May 11 2009 12:34pm |
I already have a new wheel (fleabay job) there is a whole for the buttons, I think the multicomm unitl from parot handles the info from the buttons so the ecu isnt required, i could be wrong though. |
Mon May 11 2009 12:52pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
I'm fairly sure if you ask a good dealer you can buy the buttons separately.
Mon May 11 2009 1:16pm |
I'll give that a shot, thanks martin. |
Mon May 11 2009 1:18pm |
