Home > Australia & New Zealand > UHF Radio fitting issues
Jimmy Salsa
Australia
Took my new GME UHF to our local communications specialist only to be sent on my way after a half an hour with the installer throwing his hands up and putting the RRS in the 'too hard' basket.
He took one look at the engine bay and the limited options for mounting the aerial and said that installation could end up costing more than the radio and he honestly didn't know where to start.
Can anyone give me a heads up as to how they installed their UHF and a good referral for someone who knows what they're doing when it comes to RRS installs.
Cheers and thanks in advance. 'Black Betty' Java Black RRS 07 TDV6
Post #223911 Thu Apr 30 2009 12:18pm
Not an expert but there is an empty battery compartment in the bonnet area - surely they could fit it there. 2005 Zambezi TDV6 - Gone but not forgotten
Post #223912 Thu Apr 30 2009 12:23pm
Jimmy Salsa
Australia
The unit is a small base station with the display and controls all built into the handset so the base needs to be installed either under the seat or under dash.
http://www.gme.net.au/products/radio-commu...ios/TX3440
The two main issues were:
1) Where to fit the aerial (no nudge bar or racks)
2) How to get the cable through the firewall 'Black Betty' Java Black RRS 07 TDV6
Post #223917 Thu Apr 30 2009 12:43pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Might be worth a PM to rangie who whilst no longer uses the forum may be able to help. He had one i believe mounted on his Sport (now long gone). Might be a picture of it in my gallery, if not i will try and upload one tonight when i get home
Cheers Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #223969 Fri May 01 2009 2:47am
Jimmy Salsa
Australia
Many thanks Zilch 'Black Betty' Java Black RRS 07 TDV6
Post #223970 Fri May 01 2009 3:05am
Zilch
Jimmy might be worth also asking over at the D3 site, must be quite a few with the radios fitted, cannot be that dissimilar under the bonnet
Post #223977 Fri May 01 2009 6:15am
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
It definitely is possible...
I've no idea whose car this is as a friend sent me this picture, but there is a D3 in the RRCV that has the same type of number plate mount for their aerial:
Post #223986 Fri May 01 2009 7:50am
Zilch
2nd that was "rangies" as known on here before he sold it last year. My first outing with the Sport was with him and a very good friend of his who had a very well put together Landcruiser up and around Lithgow and black fellows hand trail they are both in my gallery.
Jimmy you can ping him on http://forum.australia4wd.com/index.php?act=home his tag is Bungee on that site, now drives a Prado
edited because you have already pinged Stephenw Embarassed Another Pommie Bar Steward down under
Post #224003 Fri May 01 2009 10:01am
Jimmy Salsa
Australia
thx 2nd and Zilch for follow-up.
Looks like a reasonably simple solution - will be interested to hear if there was a standard fitting or whether he had something fabricated which is what I've been investigating today.
Cheers and Beers
Jimmy 'Black Betty' Java Black RRS 07 TDV6
Post #224073 Sat May 02 2009 7:22am
