Home > Maintenance & Modifications > Side Vents
Artful Dodger
Side Vents
Can anyone tell me if the mesh and blades are removable from the surround i want to get colour coded or do they have to be masked up?
Also does anyone know how much the range rover logo on the rear tailgate will cost if the old lettering cant be re used after removal?
many thanks in advance>
Post #222396 Wed Apr 15 2009 8:30am
They get masked up I believe, never actually seen the work being undertaken.
The "RANGE ROVER" lettering on the back is available as an LR part (each word is a separate part!) for about £80 the pair.
Post #222414 Wed Apr 15 2009 10:30am
Rupert
Ireland
The vents do come apart.
Just be careful, as you're dealing with relatively flimsy plastic tags. But some gentle persuasion with a screwdriver & you’re sorted Thumbs Up
Post #222418 Wed Apr 15 2009 10:51am
Rupert
Ireland
Ok so, I went out to the workshop & got one of my spare vents & took a few pics.
To remove the blade/mesh insert from the surround, you need to prise the two tags outwards in the direction of the yellow arrows, while at the same time gently releasing the two tags circled in red as you lift the insert upwards in a hinging motion.
It will all be obvious when you go to do the job, which will result in the two parts being separated.
Post #222422 Wed Apr 15 2009 11:21am
Thanks Rupert Thumbs Up
Post #222466 Wed Apr 15 2009 2:20pm
Artful Dodger
Rupert,
You are a star, many thanks for that! that will make my bodyshops life easier as i can drop the parts into them!
All the best
As for the lettering, has anybody re used it, £80, that is extortion! i will be prising them off very carefully indeed..
Post #222467 Wed Apr 15 2009 2:23pm
It is easily reused, you just have to be careful taking them off Very Happy
Post #222469 Wed Apr 15 2009 2:24pm
Rupert
Ireland
Glad I could help Cool
Post #222483 Wed Apr 15 2009 4:16pm
