![]() | Home > General > Range Rover Sport *STEREO Problem* (Low Power Mode) |
The low power mode message is what you get when you leave the stereo running on the battery alone.
check battery.. Malaysia Boleh!
amd2005leasing Member Since: 14 Apr 2009 Location: MÜNCHEN Posts: 10 ![]() ![]() ![]() |
the battery is okay !!! |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
How did you check the battery? This is one of the signs that the battery is on its way out. |
If i start to drive the car, the music goes to 35 max. loud.
So, let's try to understand what Google Translate is telling us |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
i think you need to turn up your hearing aid |
Normally when the car is only when the engine is running at max. 35 make loud!
It really has to be the battery or alternator - it's the only time the radio switches to low power mode. 2005 Zambezi TDV6 - Gone but not forgotten
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Maybe Angel can speak in German to him... and translate properly... Range Rover Vogue ‘17 TDV6
Es ist nicht nötig Ich spreche ausgezeichnet Deutsch! 2005 Zambezi TDV6 - Gone but not forgotten
Et je parle un excellent francais aussi ! ![]() Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Also bei Range Rover Sport kann man ja nur wenn der Motor läuft auf max. 35 Drehen !!! Wenn der Motor nicht läuft und man will die musik lauter drehen geht das nur bis 20 !! OK NORMAL !! Aber ich starte das Auto und die Musik geht bis 35 und danach nach ca. 5 min geht nur max. 20 (LOW POWER MODE) DANKE FÜR HILFE |
Wahrscheinlich, weil man Akku wird leer. 2005 Zambezi TDV6 - Gone but not forgotten
