Home > Technical > Air con on auto
ChrisP
Air con on auto
Could somebody please help me so I'm not going daft.
My car is in today for some warranty work including the air con.
Just so I'm sure,if you turn the air con control fully up or fully down but still on temperature control i.e. not the end coloured stops do you get full flow out of the face vents?
I'm sure it did when I first got it but now it doesn't,I just get max flow up onto the windscreen. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #192600 Tue Oct 21 2008 8:17am
Depends what buttons you have pressed. Silly question - sure the vents are open? 2005 Zambezi TDV6 - Gone but not forgotten
Post #192632 Tue Oct 21 2008 1:13pm
ChrisP
VA,
Even I'm not that thick Wink
With it on Auto if I move the temperature control from say 20c to either extreme but still on the numbered scale e.g. say 16 or 24 then the fan speed increases but no flow comes out of the face vents it all goes up to the screen/footwell.
If however I turn the temperature knob to the extremes either side i.e. very cold or very hot then the face vent then blows either very cold or very hot.
Also with it at either extreme but still on the numbered section and I press the manual face vent switch it comes out at a high flow either hot or cold so definately no actual problem with the manual flaps on the face vent outlets.
Problem is if I get in and leave it on Auto and it is hot it takes forever to cool down and if it is cold it takes forever to get warm.
I'm sure it did it up until a few weeks ago but not 100% sure Embarassed MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #192645 Tue Oct 21 2008 1:46pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Sorry to inerject, but one of the many reasons I love the FFRR, as the face vents are independently controlled to the main climate controls and have their own temperature selection, as in the BMW range.
Carry on.... L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #192672 Tue Oct 21 2008 2:54pm
ChrisP
We should add that to our "wish list" on the other thread.
We want hot faces - cold bo Censored ks Cool
In one of my previous cars a MY2000 MB E320cdi I had the air conditioned AMG seat option,not cheap I think the seats were about a £4k option all in but wonderful on a scorching hot day no sweaty back or pants Thumbs Up MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #192675 Tue Oct 21 2008 3:11pm
Mrs VA would beg to differ! Shocked 2005 Zambezi TDV6 - Gone but not forgotten
Post #192676 Tue Oct 21 2008 3:13pm
ChrisP
VA
Or of course visa versa Laughing MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #192678 Tue Oct 21 2008 3:16pm
Bobby
You could try this simple test to check the motor and flap operation...
Climate Control Distribution motor self-test
The motor and flap operation can be checked using the on-board distribution motor self-test function.
The self-test can be initiated by pressing and holding the ECON and RECIRC buttons while turning the ignition switch to the ON position. The control module will then compare the current motor position with the values stored in the module and will indicate an error by flashing the ECON LED (light emitting diode).
If there are no errors, the LED will go out and the system will function normally.
To confirm that there are no errors, turn the ignition switch to the OFF position, then back to the ON position.
Observe the operation of the programmed defrost LED.
If there are errors present, the programmed defrost LED will flash and the system will attempt to calibrate itself. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #192731 Wed Oct 22 2008 1:18am
ChrisP
Thanks Bobby
If I get it back and still not working I'll try that. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #192744 Wed Oct 22 2008 6:28am
ChrisP
Just got the car back and it seems I am daft,apparently it is working as it should. Embarassed MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #192798 Wed Oct 22 2008 5:35pm
Bobby
Laughing Laughing Laughing Malaysia Boleh!
Post #192824 Thu Oct 23 2008 12:02am
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
i have had a similar problem...
mine auto mode works for a while and then decides i no longer have a need for
temperature controlled air flow and packs it in....i then need to press the eco button,
the and the vents are reopened...and back to auto...
took in to the dealer...and wow they reckon nothing is wrong...!!!
well they can start replacing parts then...
and i have tried wit auto off., select face vents , and setting fan speed....after about 20mins...
it decides i dont need any air and closes off the vents...
sometimes too much electronics is self defeating. Toyota Corolla...Sad((((
formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse
Post #222038 Sun Apr 12 2009 2:41am
it is not correct
p.s. I was involved with the development of the RRS A/C unit and know it well
Post #222046 Sun Apr 12 2009 8:26am
it is not correct
Post #222047 Sun Apr 12 2009 8:26am
tastech
Thanks Kaine, but the dealers are clueless as to what to do...or unwilling.
THey say the diagnostics show no errors....so my first instinct is maybe the sensor is faulty..
any suggestions you can offer to pass onto the dealer?? Toyota Corolla...Sad((((
Post #222048 Sun Apr 12 2009 8:37am
