Home > Maintenance & Modifications > How i can remove the interieur badge´s
bananenschale
Germany 2009 Range Rover Sport TDV8 HSE Santorini Black
Hey,
today i got the badge for the door panels and for the steering wheel. but, how i can remove the old one? it looks a little bit complicated. i tried with my fingers but without any result. Laughing
thx tom RRS TDV8 Modelyear 2009 with some modifications.
Post #221715 Wed Apr 08 2009 11:37am
C10KO
Dorr card badges are easy to remove by using i.e. a small flat screw driver.
The steering wheel badge holds on four "metal things" (do not know how to call it properly) that need to be removed. Use your swiss knife for opening conserves and be gentle... It requires patiance but soon you realise where it holds and what you need to remove.
Have done mine with no harm in less than 10 minutes Thumbs Up
Post #221716 Wed Apr 08 2009 11:41am
You can prise the door cards off easily enough, once you get under them with a small flatblade screwdriver.
The steering wheel badge can be removed by drilling a small (don't forget the airbag's under there) hole in the centre, screwing in a small screw and pulling the screw back out with pliers.
Post #221718 Wed Apr 08 2009 11:44am
Or remove the steering wheel badge by drilling a small hole in the badge, screw in a larger screw and gently pull the badge out using pliars. 2005 Zambezi TDV6 - Gone but not forgotten
Post #221719 Wed Apr 08 2009 11:44am
Is there an echo in here? Laughing
Post #221723 Wed Apr 08 2009 11:49am
Evil or Very Mad Evil or Very Mad Laughing 2005 Zambezi TDV6 - Gone but not forgotten
Post #221729 Wed Apr 08 2009 11:58am
C10KO
When screwing in the steering wheel do not forget to wear a helmet Rolling with laughter
Post #221748 Wed Apr 08 2009 2:37pm
bananenschale
Hey,
thx. At the doors i tried to remove the parts.. it worked Smile
tomorrow i will change every badge!
today i had an little accident. A truck drived in my fender Sad
Have to change it... perhaps i get more money and then i will change my front bumper Very Happy RRS TDV8 Modelyear 2009 with some modifications.
Post #221783 Wed Apr 08 2009 7:51pm
C10KO
Post #221786 Wed Apr 08 2009 7:57pm
bananenschale
Hey,
i done it in 2 minutes Smile thanks. But the badge from the steering wheel i cant remove. its hold by clips, and the black one dont have them. the new looks like if someone had cut this little clips (i think there are 4).
now i just need 1 for the trunk. RRS TDV8 Modelyear 2009 with some modifications.
Post #221867 Thu Apr 09 2009 1:38pm
C10KO
Use glue or double sided strip for the steering wheel badge mate Whistle
Post #221871 Thu Apr 09 2009 2:29pm
