![]() | Home > Technical > smoke + underpower |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 ![]() ![]() |
Those symptoms indicate the turbo, blown intercooler hose or the EGRs. Since you say the EGRs have been changed, that points to the turbo or intercooler hose. The hose is easy to check and i assume your mechanics would have done so. Quite a few members of www.disco3.co.uk have had turbo failure (same engine) but none have had to pay �1400......
TOO 2 FAT Member Since: 28 Feb 2009 Location: birmingham Posts: 18 ![]() ![]() ![]() |
thanks leo for the reply. No warranty has just expired in christmas time. I have tried several times to extend it. They just tel me they will fone me back which they never do. So il have a look at the intercooler hose. So after this u think the next step is the turbo. "LIVING IT LARGE" |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
i noted that you said egr valve ther is 2 of these i had mine replaced car was struggling to start and it was a bit rough it made so much differece when the 2 of them were replaced |
yeh they are two of these. When they checked it they told me 1 was fine nd the 1 on the right was knackerd. Problem is i spent �388 yestrday 2 get 1 replaced �135 for the part rest was 3 hours labour which i thougt was a bit too steep. But they hav tld me other 1 is fine. Iv drove it 2 work this morning it has been fine on cold start very little smoke nd ther is lot more power. But half hour later same thing again. "LIVING IT LARGE" |
Did you ask for the fault codes when they dignosed your car?
bex Member Since: 24 Mar 2008 Location: Abingdon Posts: 179 ![]() |
Intercooler hoses are notorious for collapsing and being 'sucked in' on themselves.....I had an audi tt that had this problem but it took them 6 months to finally diagnose the fault...would only happen when car was very hot...so 5 mins round the block 'road test' will not find the problem....usually happened after 20-30 mins dual carriageway 'thrash'....
thanks for the advice guys. I wil definate get the valves blocked first and have a look at the hoses then take it frm there. "LIVING IT LARGE" |
had the car checked out again 2day by je engineering. They have picked up 3 fault codes on the diagnostic. 1. P029e= injector 2 is down (fuel trim at max limit). 2. P121a= inj balance, one cylinder restricted. 3. P0299= turbo under boost. They took the car for road test. Put it back 2 original settings. The turbo seems fine when u drive. Just shows fault on computer. They hav now suspected the intercooler might hav a hole in there bcuz they found oil in middle of core. So advised me 2 change dat first. To c if the blak smoke clears or not. Has any1 experienced dis and any suggestions please!. "LIVING IT LARGE" |
devenney16 Member Since: 13 Mar 2009 Location: glasgow Posts: 1 ![]() ![]() ![]() |
hi did u get the problem sorted?? i have a 2005 rr sport and it has started loosing power between 1 - 2.5 thousand revs then seems to have plenty of power, also ther is some more smoke than normal. any suggestions?? #Devenney# |
yeh sorry to get back late. finally had the car sorted it turned out to be the intercooler rather then the turbo. it had a crack and was full of oil. had it remapped from them aswel. although it set me back nearly �800 |
