Home > General > Help... Need a set of Vents... |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
If you have the correct tools then vents 5 minutes each max |
Sun Mar 15 2009 5:57pm |
What tools? You don't need any at all, they just pop out and pop back in if you release the corners in the right order! Jaymann wrote a step by step guide to doing this job, complete with photos and it's in the modifications section and stickied so it's easy to find! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Mar 15 2009 6:05pm |
flight Member Since: 24 Jan 2008 Location: London Posts: 186 |
Great info guys...
Sun Mar 15 2009 7:07pm |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Probably see you in the week then!
Sun Mar 15 2009 8:48pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
You can't have everything................................................ optherwise you'd be called a stealer |
Sun Mar 15 2009 11:14pm |
[quote="Charles Hurst Park Royal"] Probably see you in the week then!
Sun Mar 15 2009 11:44pm |
You need as minimum a trim removal tool or very flat blade to pop the retaining clips |
Mon Mar 16 2009 9:34am |
I changed the colour coded vents on my last RRS back to the standard issue without using any tools, BUT you have to start in the right place and then they will come out very easily without popping any clips or potentially damaging the paintwork. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 16 2009 10:07am |
Yep , managed to sort the vents out. Very easy when you know how. Thanks Jaymann... Also , does anybody know of a reasonable garage that can fit my handles , in North London or close??? |
Mon Mar 16 2009 9:02pm |
Thanks mintleaf for leeting me use your vents while mine are getting sprayed. Your a star... |
Tue Mar 17 2009 9:04pm |
Okay...
Wed Mar 18 2009 10:56pm |
