Home > Technical > Engine System failure
bananenschale
Germany 2009 Range Rover Sport TDV8 HSE Santorini Black
Today i had this problem:
Engine System Failure!
Cool. Shocked Switched off the engine, waited 3 minutes and it works! what could this be? ok, at 120 km/h i switched the gearknob to N (have to save diesel at this hard time Very Happy ) perhaps this made this problem? RRS TDV8 Modelyear 2009 with some modifications.
Post #215671 Fri Mar 06 2009 10:26pm
Tim in Scotland
Shocked Shocked "coasting" at 70mph! I think you may have confused numerous ECU's into submission / total confusion Mr. Green 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #215673 Fri Mar 06 2009 10:34pm
C10KO
Mate, is it a V6 or V8? Do you have DPF?
If so, I bet it is some f Censored sensor...
Post #215687 Sat Mar 07 2009 6:20am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Maybe you confused the EGR (Exhaust Gas Recycling) unit. Most engine failure lights are caused by the EGR "sensing" a problem. If the light has cleared it should be ok. RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #215705 Sat Mar 07 2009 8:37am
bananenschale
I have the V8 Thumbs Up
I drive often with N.. nothing happens till now. Censored . I also have the dpf. i thing some sensors stopped working or anything else. after that i had no problems.
last week my pdc didnt worked. i should go next week to LR, they will repair it. yesterday, it worked again.. landrover said, its "damaged". I think its an loose connection RRS TDV8 Modelyear 2009 with some modifications.
Post #215723 Sat Mar 07 2009 11:17am
C10KO
F Censored sensors Rolling with laughter
Stealer mate... Thumbs Up
ECU will have the fault stored and hence easy job to solve...
Post #215752 Sat Mar 07 2009 3:11pm
