![]() | Home > Maintenance & Modifications > How easy is it to remove the reflector from the headlights?? |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 ![]() ![]() ![]() |
definately not easy, you have to put your headlight in the oven, then pry it open, then unscrew some stuff, then take out the reflector and then do it all in reverse and hope it seals back up properly |
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 ![]() ![]() ![]() |
Don't do it. Pay someone to do it and make sure they will give you warranty that you will never have to deal with moisture inside the lense. Also have them but in Halos while they are in there. Also- paint the inside to match your body of the car.
neeslo Member Since: 28 Feb 2009 Location: Cheshire Posts: 7 ![]() ![]() ![]() |
Guess it's not a quick 20 min job then like I thought it would be |
