![]() | Home > Maintenance & Modifications > brembo brakes |
bellautos Member Since: 16 Feb 2006 Location: York, NorthYorkshire Posts: 496 ![]() ![]() ![]() |
Ive just fitted a brand new set to mine and the calipers are already in a black finish.
FAT_RRS Member Since: 18 Jun 2008 Location: COLORADO Posts: 98 ![]() ![]() ![]() |
Can the HSE take Brembo brakes? I had a set of the Brembos on my SRT 8 300C a couple of years back. I loved those brakes. All I can find is $5K USD Gran Tourismo sets. What did you guys (who didn't get them stock) use to get Brembos?
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 ![]() ![]() |
Was thinking of just masking up the area where the Brembo logo is and doing it my self.... |
Was even thinking of using Hammerite.... |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 ![]() ![]() ![]() |
I've had a set of Brembo calipers and tried to fit to mine TDV6 HSE but could NOT as the two bolts from the frame were different from the caliper (distance). Can someone tell me what modification I should do OR else??? Thanks. |
I've tried to fit these to my TDV6 HSE but the two bolt distances from the frame are different from the calipers. Have I got the wrong calipers (from RR Sport OR just RR), I wondered??? ![]() ![]() ![]() |
You may have the wrong calipers... the FFRR and RRS don't have the same fittings.
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
Yes the Hawkes work on the Brembos look great in red - but they need the car for approx 4 days........ |
I found the same when fitting calpiers to mine, i got some from a FFRR and the bolts were 12mm diamiter and my car had 16mm diamiter bolts.
Snowski Member Since: 13 Apr 2009 Location: Amsterdam Posts: 39 ![]() ![]() ![]() |
Here are some nice red Brembos for sale...
Anyone out there got spare Brembo calipers, I need for my TDV6. Thanks |
TikoV Member Since: 10 Mar 2009 Location: Glasgow Posts: 114 ![]() ![]() |
Whilst on the subject of brembo brakes..... I noticed that the discs aren't but just the calipers??
Another SW Member Since: 14 Mar 2009 Location: N Bucks Posts: 180 ![]() ![]() |
Cross-drilled brake discs are not good on off-road vehicles! The mud clogs up all the holes and then you can't stop! ![]() |
Ah I see....better order my cross-drilled ones then. I'm probably the only on-roader here |
