![]() | Home > Maintenance & Modifications > Mud Flaps |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
real easy m8 come with instructions screw holes are allready there |
filaborg Member Since: 03 Feb 2008 Location: Essex Posts: 161 ![]() ![]() |
Many thanks kind sir.... |
Silly question but can you get away without removing the wheels.... |
I believe so if you use a socket set with a phillips head attachment. But not 100% sure. 2005 Zambezi TDV6 - Gone but not forgotten
glenn Member Since: 05 Nov 2008 Location: Hampshire Posts: 26 ![]() ![]() ![]() |
Done mine with out taking the wheels off took about 15 minutes really easy. Make the car look much better with them on Range Rover Sport HSE,Java Black,Allround Tint's, Black and silver badges,Black and silver wheel centers,Up graded leather,Brembo brakes,white side repeater lenses,led number plate bulbs,led side lights bulbs,led reverse lights bulbs, led interior bulbs,Front and Rear mud flaps. Looking for private number plate. black and silver front grill and side vents and replaced the boot strip with black one |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Yes, an offset Phillips screwdriver helps a lot with the flaps for the rear wheels (or a Phillips head on a socket like VA mentioned), the front wheels are no problem as you just steer them out of the way. ![]() |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Funny how we are all different.......
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 184 ![]() |
got to agree with you there, I think flaps make any RR look a bit odd. The only RR flaps suited imho is a Classic |
neeslo Member Since: 28 Feb 2009 Location: Cheshire Posts: 7 ![]() ![]() ![]() |
Mud Flaps = Ewww! No offence people, maybe it's an age thing?? -----------------
