Home > Maintenance & Modifications > Nav-TV video in motion |
incomis Member Since: 05 Jun 2008 Location: Sofia Posts: 4 |
Two weeks ago I buy and install this VIMCANROV-LR which is www.nav-tv.co.uk "Video In Motion" Interface CAN for Land Rover Discovery 3 / Range Rover Sport (MOST) system (http://www.nav-tv.co.uk/products/vimcanrov-lr?car=133).
Wed Feb 25 2009 8:24am |
DiscoStu Member Since: 10 May 2006 Location: Essex Posts: 47 |
Is this how the unit works, by fooling the car into thinking it's always in neutral? A D3 not in drag....
Wed Feb 25 2009 8:41am |
This is my question too ... |
Wed Feb 25 2009 8:45am |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
If you have the active Nav-TV hack, that's normal. The module does indeed trick the electronics into thinking the car is in neutral all the time, and the trick spills over on the 4x4 Info screen. Other than the "N" displaying at all times, no harm done. The remaining sensors still indicate what TR mode you are in, if you are in Hi or Low, HDC, lockers, compass, suspension and steering angle graphics all work, etc. |
Wed Feb 25 2009 3:51pm |
Could this LR enhancement be for the same purpose...?
Wed Feb 25 2009 11:00pm |
Every time I see that "Navigation on the move enhancement" bulletin I get royally pi d as it's still not available to us in North America, and it most likely never will be, no doubt thanks to our litigious society. Nevertheless, I believe that modification would do nothing to correct the Nav-TV induced issue above, since the satnav uses different signals (a combination of wheel speed sensors and GPS communication) than the RSE/video system hacked via the Nav-TV module, to determine if the car is moving or not. |
Wed Feb 25 2009 11:30pm |
Thank you. This sound good for me. Best regards. |
Thu Feb 26 2009 6:56am |
