![]() | Home > Technical > No power + Black smoke?! |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 ![]() ![]() ![]() |
HI Kevin . i don�t know if this will help but I know one guy over here and he had a similar problem and at the end the problem was on of the one of the Twin Turbo�s. Apparently there was one rubber tube/pipe on the Turbo which had an air leak(I don�t know now if it had a small crack or it was not connected tight). I really hope that it will help you |
There is a Service Action related to RR Diesel... "A diesel particulate filter pressure sensor hose fitted to the left-hand side of the exhaust system may have been incorrectly installed during vehicle manufacture resulting in the hose being twisted. This can give an incorrect pressure reading and result in inadvertent 'limp home mode' being activated." They just need to untwist the hose, if that's your problem!! Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324 ![]() ![]() ![]() |
it deffinatley sounds like a gasket problem. And if you have a turbo ( i haven read everything) the gasket could easily be blown. I had this exact problem on another vehicle of mine... you could also have a main block blown gasket, its most likely one of the two. |
kevinthefruitbat Member Since: 16 Nov 2008 Location: Europe Posts: 6 ![]() |
Thanks for the suggestions. I will try to get it to the dealers before the silly season gets under way! Will let you know what is discovered! |
Sorry it took so long to get back on this one. Computer was reset to factory set up after Xmas. Had 1 Engine system fault show up, while I was out cleaning the DPF. Then the next day, it spluttered while I accelerated. However, it didn't go into limp mode. Rang dealer today and they have a new program to install that is supposed to address any problems caused by the DPF. I have spoken to someone who works with Audi, VW and Mercedes. They have had a lot of trouble with DPF too and I've noticed some of you on this forum experiencing the same problems. I'm am in the process of selling my RR, and I want it to go in the best condition it can be. So hopefully, it won't be in my possesion for much longer! |
Car was sold last week. It was still trying to kill it's new owner! He went to the dealer and they found that a collar on one of the exhaust system pipes was not screwed on properly. I thought how great for this guy, as he won't have to suffer as I did. He phoned up later that today to say that it still does it! I've gone back to Jag for time being. Goodbye forever LR and good luck to all you guys who own them. Looks like you need it!! |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 ![]() ![]() |
BS |
