Home > Technical > US spec. rear lights
C10KO
Did anyone try to modify the standard UK MY09 rear lights to the US style? Is it possible at all? If so, any idea how?
Thanks for your views on this one... Thumbs Up
Coko
Post #213201 Sun Feb 22 2009 5:58pm
C10KO
Since no one seems to get caught by this topic a question to one of you “electricians”.
Do you think it is possible just to connect a holder for a W5W bulb on to the wiring for the rear light and so activate the rear side light?
Or am I talking total rubbish?
Thanks in advance for you input…
Post #213999 Thu Feb 26 2009 4:10pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
FYI, the side marker bulbs are 3 watts on NAS spec cars. Don't know if the bayonet mount is there - unused - on assemblies outside of North America.
Post #214032 Thu Feb 26 2009 6:28pm
C10KO
Not quite sure mate, need to check that...
But thanks for the info Thumbs Up
Post #214034 Thu Feb 26 2009 6:31pm
umbertob
1 - Side marker lamp bulb (NAS only)
2 - Stop/side lamp bulb
3 - Stop/side lamp
4 - Side marker lamp (NAS only)
5 - Fog lamp
6 - Reverse lamp
7 - Reflector
8 - Electrical connector
9 - Reverse lamp bulb
10 - Fog lamp bulb
11 - Turn signal indicator lamp bulb
Post #214036 Thu Feb 26 2009 6:39pm
Rupert
Ireland
Excellent info umbertob Thumbs Up
By any chance you wouldn't have similar for the front, would you ? Whistle
Edited to add………
Did a bit of digging & a search turned up a few threads.
This is a quote pulled from This Old Thread….
Quote:
……..this can actually be done with a little elbow grease and minor electrical know-how. I have a UK spec sport and have done this modification. For the front side lights, the bulb holder is already there and you will need to get some bulbs and some wiring. I used the marker lights off my old ML270 which fit perfectly. For the rear lamps you would need to actually drill into the lights socket to be able to fit the lights. WIring is merely tapping into the running lights.
Another thread of interest on this subject over on the D3 site, can be found Here
Along with some pictures Here
Post #214057 Thu Feb 26 2009 11:17pm
Bobby
I have this...
will it do? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #214058 Fri Feb 27 2009 12:09am
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
what exactly are we talking about here ?
Post #214076 Fri Feb 27 2009 8:34am
Rupert
Ireland
Bobby wrote:
I have this........
......will it do?
Post #214084 Fri Feb 27 2009 8:56am
bananenschale
Germany 2009 Range Rover Sport TDV8 HSE Santorini Black
Has someone an pic from the us rearlights? what is different to the european ones? RRS TDV8 Modelyear 2009 with some modifications.
Post #214227 Sat Feb 28 2009 12:07pm
C10KO
@umberto and bobby thanks guys... Though I am not quite certain whether i am brave enough to DIY with electrics Big Cry
@ bananenschale Similarly as on the front lights, there is a red light on the side... To me it looks great Thumbs Up
Post #214256 Sat Feb 28 2009 6:37pm
