Home > Technical > All Season Tyres
Tim in Scotland
Yes, everything is the same, even the tyre pressures remain the same. 33lbs at the front 36 at the back. Just check that you can find your locking wheel nut key before you go in though............ it should be in the holder in the boot 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #209681 Mon Feb 02 2009 4:50pm
Mintleaf
cheers Tim... RR Sport TDV6 HSE 07MY Java Black
Post #209682 Mon Feb 02 2009 4:56pm
Korenai
Switzerland 2007 Range Rover Sport TDV6 HSE Java Black
Tried the Hankook Ventus in a grass field, about 10 cm covered in snow, uphill and downhill (not too steep). They're good! Tried to brake hard as well, the car almost stopped right away. Need some more test on tarmac now, but the snow is alla gone...
Post #211510 Fri Feb 13 2009 7:20pm
