![]() | Home > Technical > Parking Sensors - Weird stuff!! |
nigelkippax Member Since: 29 Jul 2006 Location: Glasgow Posts: 19 ![]() ![]() ![]() |
Here's one for you. I've moved to a new place that has a under ground car park. When I put the car into reverse to go in or out a space the sensors go nuts. Full tone from the front when I'm reversing into space, full tone from the back when standing still etc. Even if I turn them off then on again they still go crazy!!
I know when i had a go in Will Wonka's SC last week they were doing the same but think his PDC has a problem RRS TDV6 Gone but still around
dadanek Member Since: 30 Mar 2008 Location: Heart of Europe Posts: 450 ![]() ![]() ![]() |
I had similar problem, and it was caused by number plate holder. It was a little bit slack... All what I do was rescrew the holder and problem solved... RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT |
Do a search, we've discussed this before and there are solutions! |
It's none of the above. It ONLY happens in this underground parking garage. |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 ![]() ![]() ![]() |
How close are you to the side walls in your underground carpark. My rear ones turn solid as i reverse into my garage as I go through the door aperture as the car thinks there is not enough room on the side even though there is. Once clear of the areture they go back to normal. |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
Maybe it is this:
