Home > Technical > Knocking noise
seanwolley
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
Knocking noise
I have a knocking noise from under the car when i drive over bumps sounds like its coming from the rear, garage cant find a thing wrong but i have noticed the to swinging wieghts next to the exhaust knock against the body if you swing them hard could this be it, should they be that loose? The car is a 55 plate SC
Post #210991 Wed Feb 11 2009 8:57pm
Have a look at this!
http://www.rrsport.co.uk/forum/topic7227.html RRS TDV6 Gone but still around
Post #210993 Wed Feb 11 2009 9:04pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
The knocking noises from the front of the car are well documented and discussed at length.
Knocking from the rear is a rarer phenomena. The dangling weights would be very unlikely to swing enough to catch anything - unless you have fitted some new exhaust tips or similar. Even then the weights hitting those would be unlikely to be evident inside the vehicle. If you can "feel" a knocking, its likely to be suspension, transmission (like rear diff) or brakes or unbalanced wheels or a loose exhaust pipe. All of those should have been pretty obvious to a half decent garage though. RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #210999 Wed Feb 11 2009 9:41pm
Tim in Scotland
One thing I would check is that the spare isn't hanging down slightly, could be loose in the stowage and bumping around. Open the boot, take out the tray of tools and give the winch a couple of turns to see if it is tight 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #211004 Wed Feb 11 2009 10:14pm
Also check the heat shield is secure - that was the cause of my rear knocking! Shocked 2005 Zambezi TDV6 - Gone but not forgotten
Post #211007 Wed Feb 11 2009 10:23pm
