![]() | Home > Technical > Passenger seat belt alert |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I guess - or get the missus to sit in the back |
klm Member Since: 30 May 2006 Location: UK Posts: 155 ![]() ![]() |
It's more bloody annoying when you have a water bottle or laptop on the seat and it keeps flashing |
and bonging |
Killerbob Member Since: 27 Sep 2008 Location: St. Gallen Posts: 145 ![]() ![]() ![]() |
...but it sounds like a bad sensor, right? RRS TDV8, black with ivory. |
Sounds like it |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
You can also stop the sound definitly:
Doesn't work on the newer ones - cannot recall MY think it may be MY8.5 onwards |
too bad... |
RRSKildare Member Since: 27 Jun 2008 Location: Kildare Posts: 6 ![]() ![]() ![]() |
Hi There,
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
I had the same problem a while back. You have a faulty pressure sensor under the passenger seat cushion. Your local dealership should replace the seat cushion under warranty. |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
worked on mine and mine is an 08 plate.......you need the key turned to 1st ignition point |
The pressure switch in the occupant detection system (except NAS vehicles) which determines if the front passanger seat is occupied or not could be faulty/stuck . It is installed between the foam padding and the cover of the seat cushion.
It does work even on newer ones... The belt minder function can be enabled and disabled using the driver safety belt switch. The instrument cluster changes the state of the belt minder function if, within 60 seconds of first turning the ignition switch to position II, the driver safety belt is fastened and unfastened nine times. Successful completion of the change is indicated by a single chime and the safety belt warning indicator flashing five times, at 2 Hz. The belt minder function can also be enabled and disabled using T4. ![]() ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Bobby - if that works |
