Home > Technical > Adaptive Headlights
Adaptive Headlights
I keep getting flashed by oncoming cars when my headlights are on so I've come to the conclusion that either 1. They love the car, or 2. I must be blinding people though badly aligned lights.
Is there a way of adjusting the lights or is this a visit to LR service? 2005 Zambezi TDV6 - Gone but not forgotten
Post #209133 Fri Jan 30 2009 7:37am
Peter
United Kingdom 2006 Range Rover Sport SDV6 Autobiography Java Black
Hi VA
I travel to Belgium almost monthly so have become used to changing the lights to left hand drive setting from their UK setting when on the Eurotunnel train.
This is not very clear in the drivers manual and nor will most dealers be able to assist ( I asked 2 dealers and neither could do it). When I was at Gaydon on an LR drive day I asked one of their tech-heads there and he showed me.
You have to lift the bonnet and remove the screw-on cover on the rear of the lamp unit. Make sure there is no power to the lights as there is a very high voltage on the zenon lamps. Put your index finger in as if you were going to try to remove the lamp unit and feel for a small lever on the right hand side of the lamp unit where the connector attaches (imagine you are in the car looking towards the front - its on the right or inside for the nearside lamp).
It is normally in the "up" position for the UK setting so move it down to the LHD setting. It is not easy to find this lever and it is quite "flimsy" (not tough) so be careful not to bend it.
You would have thought that such a function would be automated on a car of this value but no, you have to get your hands dirty! It's finally gone! Replaced with BMW 730SE in Sophisto grey Xirallic finish with Oyster (Ivory) and black interior. DAB, Climate glass, Ceramic iDrive and gear selector, power boot and iPhone Bluetooth pack - luvvin' it!
I miss my old RRS "bucket" rattling around but it just had to go!
Post #209136 Fri Jan 30 2009 9:19am
Misery
I had that in the FF VA it was a trip to the dealer for me. mind you sometimes it is just old farts, cause the lights are so bright. Thumbs Up Thumbs Up
Post #209137 Fri Jan 30 2009 9:20am
McBunny
Germany 2006 Range Rover Sport TDV6 HSE Bonatti Grey
or 3. There's a speed camera ahead! Cool RRS TDV6 HSE, 2006, bonatti grey, ebony interior, rear diff, s/c grille and vents, stormers, privacy, tasmods, iphone integration Wink
Post #209142 Fri Jan 30 2009 9:30am
Pelyma
I had this with my D3 a trip to the dealers sorted it. Porsche Cayenne S Diesel 66 Plate
Post #209143 Fri Jan 30 2009 9:34am
Tim in Scotland
They are welcoming you into Saga VA!
The other thing that can be a problem for oncoming traffic when you have the adaptives is that they go through a self level check every so often and that can confuse on coming drivers into thinking you have come onto full beam.
Have you put the head lights on before starting up and then watched the "dance" routine they go through when you put the key to position 3? They sort of go "cross-eyed" then full outward pointing beams and then focused! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #209151 Fri Jan 30 2009 9:49am
Went to my friend local dealer Guava in Guildford who checked the lights and they were fine. They did however adjust them to be a little lower - there is a hex key socket at the top of the headlight unit that you can turn to adjust the level of the beam. 2005 Zambezi TDV6 - Gone but not forgotten
Post #209163 Fri Jan 30 2009 10:34am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
When you change your UK dip over for driving on the right it flattens the beam and removes the sidelobe from the left, I have right hand drive lights and they have a diffrent beam pattern when set normal. For in the uk switching them over it flattens the beam and removes the sidelobe from the right.
When they are switched over they have no sidelobes at all.
My MG has Xenon lights too, at least I don't have to remove the grill and take the lights out to swap them over Sons of dogs come hither and get flesh
Clan Cameron
Post #209177 Fri Jan 30 2009 1:10pm
Josh
Just flash them back VA they'll soon realise you are not on main beam Rolling with laughter
It's just that these bulbs are so much better than the old stuff and some people haven't caught up with that fact yet. TDV6 - gone
TDV8 - gone
Post #209289 Sat Jan 31 2009 10:42am
This is starting to p Censored me off. I will get every other car flashing me to tell me my headlights are too bright! Do others with the bi-xenon adaptives get this too? 2005 Zambezi TDV6 - Gone but not forgotten
Post #209501 Sun Feb 01 2009 8:37pm
Tim in Scotland
Yes, but only occasionally, they don't seem to bother most folks though. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #209503 Sun Feb 01 2009 8:39pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
I haven't noticed many people flashing at me. Mind you, I don't take a whole lot of notice ... RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #209504 Sun Feb 01 2009 8:40pm
Lookers Park Royal
I tend to find this phenomenon whilst accelerating hard! If someone is coming the other way and you dab the throttle it is quite easy in a TDV8 to bring the front up enough for someone coming the other way to think you are on main beam. Unfortunately the adaptive headlights can't react quite that quickly.
James Thumbs Up
Post #209508 Sun Feb 01 2009 8:47pm
C10KO
VA, I do get it from time to time when in the UK...
Just flash back Rolling with laughter
Post #209509 Sun Feb 01 2009 8:51pm
Bobby
Would this be useful to you, VA..?
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #209538 Mon Feb 02 2009 3:49am
