Home > General > Retrofit Land Rovers Tyre Pressure Monitoring System? |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Possible?
Thu Jan 29 2009 9:20pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
How much have you got? |
Fri Jan 30 2009 12:06am |
That bad boys?
Fri Jan 30 2009 11:13am |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
I've got a jig-saw, need your centre console cut out for the button??? Sons of dogs come hither and get flesh
Fri Jan 30 2009 12:53pm |
There is a blank button for the button dude! 2022 P440e AB |
It's possible I'm sure, but I have the feeling it would be lots of dough to install the whole enchilada after the fact. There is the TPMS module in the overhead console area that must be hooked up via CAN-bus to electronics / CJB, four receiving antennas behind each wheel well lining that are hard wired into the module - unless your car was prewired at the factory I can just imagine the labor charge for that job - and fairly expensive transmitters / sensors need to be mounted into each wheel, replacing the regular stem valves. And some quality time in software uploads and configurations will be necessary to activate the various components via diagnostics, so they are able to "talk" to each other and to the rest of the car's electronics, message center display, etc.
Fri Jan 30 2009 4:51pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Sorry bit OT but talking of Dough Reminds me of a story
Fri Jan 30 2009 6:57pm |
