Home > General > budgeting budgeting
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
budgeting budgeting
can someone give a rough idea for cost of:
- typical service (mileage currently:16k)
- 2 rear tyres (20")
- 2 front brake pads (brembo)
- 2 front/2 rear brake discs
thanks in advance
Post #207383 Wed Jan 21 2009 9:15pm
Adeyb
2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
Ive just bought a sport needing its 1st service, been quoted £330 inclusive
cheers
Adeyb
Post #207387 Wed Jan 21 2009 10:02pm
£330 is about right for the service, but I'd surprised if that will include replacement of brakes & tyres.
You don't say which RRS you have (and therefore what tyres you have) - but I'd think for a dealer to provide and fit discs/pads and two new tyres, you won't get much change out of £600.
Post #207453 Thu Jan 22 2009 11:29am
Tim in Scotland
It's a TDV8 or an S/C.................................... but I would guess a 2007 Java Black TDv8 Wink
Hence the Brembos and that'll be 20" wheels/tyres 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207458 Thu Jan 22 2009 11:37am
ViewWise
rough cost of all of that i reckon will be closer to £1500 including labour from a dealer Big Cry .
service £330?
2 rear tyres - £400-£500
2 front brembo pads - £100 + labour to fit (i know dealers charge about £200+ labour to fit 4 pads)
Discs all round (no idea but id guess atleast £200 for parts? ) + labour.
Simple cost cutting order tyres online or phone around.... Get discs/pads fitted by a trusted indy. Just buy the genuine parts.
Post #207459 Thu Jan 22 2009 11:39am
Yep Confused
Best thing to do is to get the dealer to quote - you at least know what sort of ballpark you're playing in then. Then it's time to get shopping around.
Post #207465 Thu Jan 22 2009 11:42am
SteveWilliams
Wales 2006 Range Rover Sport TDV6 HSE Rimini Red
Best quote I had for a 2 new 20" tyres was £220 each fitted and balanced. Dealer quoted £300 each. This was to replace like for like Continentals I think
Post #207651 Thu Jan 22 2009 6:39pm
andykart
an alternative for your tyres over winter is to look for a set of 19" alloys with new tyres on ebay or on PH.
I bought set of 4 brand new wheels and tyres for £550 - still had little spikes on tyres! Reason is many Disco D3 and lesser RRS want to upgrade to 20 or 22 so 19" are cheap.
19 are great for winter or country laning as your far less likely to damage wheel or tyres compared to 20" which are so easy to damage. I fit mine in Oct / Nov and then change back in April. 20" then like new. Yep still need to buy the new tyres eventually but you halve the wear and tear in winter months when your more likely to slide around a bit!! plus less likely to damage side walls or alloys on your 20" Andy J
Range Rover Sport, TDV8, Java Black, Ivory
Post #208342 Mon Jan 26 2009 12:50pm
