Home > Technical > lazy entry problem
rrspoland
Poland 2006 Range Rover Sport Supercharged Rimini Red
lazy entry problem
I have a problem with lazy entry. I set it to on position on the computer, but nothing happens. I asked at the dealer and they said they switched it on, but after I left the service it actually still didn't work.
Is there something additional that I need to do? Is there a way to reset it?
maybe I should do something when I set the seat position memory?
in the manual there is very little about lazy entry, and nothing about this problem.
any advice? My name: Patryk
RRS 4.2 s/c Rimini Red
Post #203864 Wed Jan 07 2009 11:38am
Once lazy entry is switched on, you then need to turn the key to position I or II on the ignition, move your seats and mirrors to the desired location then press the MEM button followed by one of the numbers. The car will beep, and a message appears on the dash display.
From that point every time you unlock the car with the key you have just used, the seat memory will operate and bring everything back to your saved settings. There's not a lot of point using it if you're the only one using the car tbh....
Post #203866 Wed Jan 07 2009 11:44am
rrspoland
thanks for the info. but from what you wrote it means that lazy entry is that the seat will automatically move to my stored position once I use "my" key. is that right?
I have an infiniti fx and lazy entry is the option that when I open the door the seat moves fully back for easier entry and when I close the door and put the key in the ignition then the seat moves to the stored position.
so which one is it? if it is what I undesrtand from your post then it is really pointless. My name: Patryk
Post #203877 Wed Jan 07 2009 12:04pm
Lazy entry settings are coded to each key and allows, for example, you and your wife to both have your own settings coded to your own keys. It's not like the equivalent "lazy entry" in some other cars where everything moves out the way (including steering column) for you to get in.
Post #203881 Wed Jan 07 2009 12:22pm
rrspoland
I see. Thanks for the info. Now I undesrtand, why it "didn't work" My name: Patryk
Post #203928 Wed Jan 07 2009 2:19pm
You can always program the Key so the seat is all the way back when you get in and the push memory 2 for you driving position Question RRS TDV6 Gone but still around
Post #203929 Wed Jan 07 2009 2:20pm
Did you have three Shredded Wheat this morning or something? Laughing
Post #203940 Wed Jan 07 2009 2:40pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
AKA Geriatric Entry... I think that feature is available on newer Sports (those fitted with power tilt/telescoping steering columns anyway.) I've experienced it on a new LR3 here and it's a bit disconcerting to see everything moving up and away when you remove the key from the ignition if you are not used to it, but I don't believe Land Rover gave it a "name". You can disable it.
Post #203960 Wed Jan 07 2009 3:40pm
flydive
Yes, RRS from 2008.5.
Used it few times at the beginning, but the novelty wears off quickly, and I'm not "fattish" like some around here Wink , can get in and out easily, so I disabled it '08 RRS TDV8
Post #203981 Wed Jan 07 2009 4:29pm
ViewWise
yea and i found sometimes if you were too quick and start the car the seat stops moving half way through the positioning. Im pretty sure i saw a 'lazy entry' option in the settings on the dash (flick through the OBC while stationary). I turn it on and off via the electricly adjustable steering column stalk though, so not sure what the menu option is for.
Post #204006 Wed Jan 07 2009 5:53pm
NO!!!
I had 4 Very Happy RRS TDV6 Gone but still around
Post #204008 Wed Jan 07 2009 6:07pm
stonosam
Australia 2008 Range Rover Sport Supercharged Stornoway Grey
Does anybody know if the steering col. adj. is in the auto position whether the seat as well as the streering wheel moves or just the seat?
Post #204145 Thu Jan 08 2009 3:40am
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Can anybody tell me how to set it up so that the column moves up and away once ignition key is removed and yes i have RFM'd but cannot find it Thumbs Up
Post #207329 Wed Jan 21 2009 5:03pm
umbertob
If you have the electric steering column adjustment switch you leave it on "Auto", I think. If you don't want seat and wheel to move, you flip the switch clockwise to the Geriatric off position.
Post #207358 Wed Jan 21 2009 6:42pm
leedsunited
Thanks Umbertob Bow down will give it a try
Post #207362 Wed Jan 21 2009 6:54pm
