Home > Technical > Can this be done ???
Page 2 of 3 <123>
Rupert
Ireland
I think though, I’d test that first with someone left sitting inside.
Just in case you can’t open the car with the second key Shocked
Post #203450 Mon Jan 05 2009 12:46pm
crowej
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Unnecessary quote removed
that would seem wise alright
Post #203453 Mon Jan 05 2009 12:51pm
MAW
That's why i think i'll try the reverse of it first, start with one key door closed and attempt a manual lock from the passenger door (assuming the manual function operates central locking and not just that door) Confused
Post #203460 Mon Jan 05 2009 1:11pm
Josh
I thought about the timer for the fbh, but to be honest I jumped in it this morning at -5 and frozen solid. Within 5 mins it was warmed and clear. So not sure the expense is worth it..................now if I lived somewhere where every day it was -15 I could be persuaded very easily to fit the timer.
Solution by a Woolly hat. TDV6 - gone
TDV8 - gone
Post #203682 Tue Jan 06 2009 11:59am
Who's Wooly hat? 2005 Zambezi TDV6 - Gone but not forgotten
Post #203686 Tue Jan 06 2009 12:16pm
MAW
How can i be sure the FBH is working Confused
Post #203687 Tue Jan 06 2009 12:17pm
Puffs of smoke from under the front of the car is the easiest tell tale sign in the cold weather.
Post #203690 Tue Jan 06 2009 12:19pm
'Puffs" More like a storm cloud appearing on the n/s front wing! 2005 Zambezi TDV6 - Gone but not forgotten
Post #203691 Tue Jan 06 2009 12:20pm
MAW
Yes i had that on the old one - very obvious - this one isn't though - but there must be a definitive way to say working or not... Confused
I am not convinced it is Confused
Post #203693 Tue Jan 06 2009 12:22pm
Put your hand near the FBH and you should feel the heat. DON"T TOUCH THE THING! 2005 Zambezi TDV6 - Gone but not forgotten
Post #203695 Tue Jan 06 2009 12:26pm
Is that how you got Keira to pose VA? Laughing
Post #203696 Tue Jan 06 2009 12:31pm
Thud 2005 Zambezi TDV6 - Gone but not forgotten
Post #203697 Tue Jan 06 2009 12:32pm
MAW
All the time or just first thing in the am? What temp does it kick in at?
Where is Bobby when you need him Confused Laughing or TB....
Post #203698 Tue Jan 06 2009 12:33pm
I don't believe it runs all the time, and it only kicks in below 3degC Very Happy
Post #203699 Tue Jan 06 2009 12:34pm
As the fat one says. 2005 Zambezi TDV6 - Gone but not forgotten
Post #203700 Tue Jan 06 2009 12:36pm
Page 2 of 3 <123>
