![]() | Home > Technical > Heated washer jets? |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
Are they standard? GONE** RRS 3.0SC Silver fully loaded |
mmmm, I have the cold climate... but the washer jet heaters not working, spent an hour driving saturday and they never worked! GONE** RRS 3.0SC Silver fully loaded |
Davel Member Since: 03 Mar 2008 Location: Kingsley Posts: 61 ![]() ![]() ![]() |
Ditto
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Ditto again |
I thought mine were heated, back in the day.... they're not heated on the Poxymobile and at 7.30 this morning in the dark and snow, I could see less and less through the windscreen as I noticed my jets were also iced up. One stop at Ripley services later and a new bottle of deicer spray I was all sorted |
I think the heated jet's only kick in when you push the front screen button??
jamiepyoung Member Since: 08 Dec 2007 Location: Finchampstead Posts: 31 ![]() ![]() ![]() |
This might explain why the jets haven't worked for about a week..... |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
Ditto.... and as i thought they were heated immediately started complaining... RTFM for me perhaps?! |
See if they heat up when you push the heated screen button? Someone please RRS TDV6 Gone but still around
Tried that no joy though |
Balls RRS TDV6 Gone but still around
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
just a thought, but was the water in the tubes feeding the jets frozen or at least slushy?
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Could someone explain to me the benefits of heated washer jets? Are you supposed to use them to de ice the screen? |
If they are frozen over then you can't use them if they heat up then you can RRS TDV6 Gone but still around
