Home > Technical > In the rear wheel arch ...electric thingy
BKHK
In both rear wheel arches is what looks like a threaded plastic bolt about 3mm long inserted from behind the wheel arch plastic liner. It has no "nut" on it. If it pops out, it dangles near the exhaust and appears to be some sort of grey coloured electric connector.
I have managed (one very dirty shirt later) to put it back into its rightful place. It seems poorly secured or fitted, a good drive on a corrugated dirt road was enough to shake it loose.
But.....what is it? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #202911 Fri Jan 02 2009 9:57am
Bobby
Hmmm.. .
The only electrical thing in the wheel arches that I can think of is the TPMS initiator. Could the electrical connector become loose?
Is your vehicle fitted with TPMS in the first place? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #202941 Fri Jan 02 2009 11:06am
mr boombastic
Australia
Yes i have been wondering what they where for too. I knocked one out by accident when i was washing inside the wheel well once. It just seems to be sitting there protruding through a hole and not secured very well. I don't have the TPS system. What is it all about? I
Post #202944 Fri Jan 02 2009 11:18am
BKHK
Hi Bobby
I don't have TPMS because mine is a basic 2.7TDV6 Aussie spec. If you look in the rear wheel arch, you will see a rounded rectangle indent with two holes, one contains the poorly secured electrical connector thingy. There is one on each side....
I would love to know what it is!! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #202947 Fri Jan 02 2009 11:24am
MAW
Can you post a pic to aid diagnosis??
Post #202954 Fri Jan 02 2009 12:08pm
Bobby
Looked around the arch (poor lighting, agreed) but could not find anything like described above. Shocked
Like MAW suggested, some pictures would be helpful.
Just thinking aloud, if this is near the rear of the rear wheel arches, this could be where the TPMS Initiators are fixed. It could be that your vehicle is TPMS prepped but not TPMS equipped. So basically you are looking at the connectors for the Initiators. Just a guess! Malaysia Boleh!
Post #203080 Sat Jan 03 2009 3:50am
BKHK
You may right there Bobby since they seem to be "terminated". I will try to post a pic but I don't want to have to disassemble the thing again having just put it all back together.
What does TPMS stand for again? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #203087 Sat Jan 03 2009 7:49am
MAW
Tyre (or the incorrectly spelled tire Wink ) Pressure Monitoring System i think......
Post #203094 Sat Jan 03 2009 9:57am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
Tyre pressure monitoring system (I think) RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #203095 Sat Jan 03 2009 10:08am
Bobby
Both Thumbs Up Thumbs Up
Smile Malaysia Boleh!
Post #203097 Sat Jan 03 2009 10:21am
