Home > Technical > hi from newbie and a few questions please! |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
I'm afraid the chances are that it will need a dealers spanner to fix that lot I'm afraid TDV6 - gone
Fri Dec 26 2008 10:40am |
V8MBO Member Since: 26 Dec 2008 Location: edinburgh Posts: 4 |
Thanks,
Fri Dec 26 2008 11:45am |
Did you buy this from a main dealer? They haven't done much of a pre-sale inspection if so...
Mon Dec 29 2008 10:42am |
Its not as bad as it seems!!
Mon Dec 29 2008 11:19am |
Fair enough - congrats on the new toy anyhow
Mon Dec 29 2008 11:22am |
richh Member Since: 15 Feb 2009 Location: england Posts: 9 |
hi guys , thee has been one case of this at our garage, it turned out to be bad wiring in the drivers door, which was blowing the fuse for both the seats and the mirrors ( i think they would only work down and in because the bcm uses the earth path to use these directions.) the lver has two small plastic thingys(technical term!) which snap- new one required, they justv pull off and push on, with a firm hand. hope this helps, Richh they all do that! |
Sun Feb 15 2009 12:18pm |
